02-23-2013, 07:27 AM | #1 |
Tire Sensors
so i changed my stock rs chrome rims to factory rs midnight silver rims w/ tire sensors and my tire monitor still cannot see the new sensors. Is there a way to learn them or do i have take a trip to the dealer?
02-23-2013, 07:34 AM | #2 |
Drives: Car Join Date: Jan 2013
02-23-2013, 07:41 AM | #3 |
9-60 is conversions and add on ons. i put oem rims and oem tire sensors on my car. im sure it is covered.
02-23-2013, 07:45 AM | #4 |
02-23-2013, 07:50 AM | #5 |
no because the rims i bought came off a 2011 camaro so i figured it must have the same sensors. i wasnt going to pay to have a tire place take the tires off the rims and swap them.
02-23-2013, 07:55 AM | #6 | |
so if the sensors are the same type, but different to the car then you have to match them per the manual. Just because it's the same type of sensor doesn't mean the car will automatically read them.. They have to be matched. |
02-23-2013, 08:04 AM | #7 |
Drives: 2010 2SS/RS Join Date: Jul 2011
TSP VVT2, OBX LTs Catless mids, Flowmaster, Half K&N, Half Fastlane Pipeline CAI, Tuned by RDP Motorsports! Thats the main fun adders
SHAKE ANNNNNNND BAKE!!!!! |
02-23-2013, 08:29 AM | #8 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
Each sensor has a 'serial number' associated with it, and the car needs to know which 'serial number' is on which corner of the car.
Even if you keep the same set on the car and just rotate the tires, the car needs to be re-told where each sensor is now. |
02-23-2013, 08:31 AM | #9 |
Drives: 2010 SS 426 V8 M/T Join Date: Aug 2012
Dealership will need to reprogram sensors
02-23-2013, 08:56 AM | #10 |
HTWEELZ
Drives: 2013 2SS Hot Wheels Edition Join Date: Jan 2013
Just buy one of these:
http://tpmstools.ca/products/tpms-pe...-use/ateq-vt15 I have one and use it on my truck when I swap from summers to winters and back. Can be used on ANY vehicle that has the TPMS sensors to reset them. Lots of my friends have come over to use it. Very simple to use and worth every penny IMO.
2013 2SS Hot Wheels Edition 727 of 1524
w/ Dual Mode Performance Exhaust, Nav, and Performance Shifter. DELIVERED APRIL 22nd, 2013 and enjoying every minute since! Mods: Cold Air Inductions CAI, CNC Ported Throttle Body, Elite Engineering Oil Catch Can, Smoked Spyder LED Tail Lights, 12" JBL Sub, JBL Amp, Stealth Sub Box, American Racing LT headers and hi-flo cats, Tuned by Davenport, Custom painted interior pieces, Custom painted hood liner and trunk liner, Niche Targa M-130 wheels, LED side markers |
02-23-2013, 09:12 AM | #11 |
Drives: 2011 1LT Join Date: Mar 2012
Yup... this here. I have done it a number of times (with tire rotations AND with a different set of rims), and it's a piece of cake. For me it was easier than driving 35 miles to the dealer...
1. Set the parking brake. 2. Turn the ignition switch to ON/RUN with the engine off. 3. Go to the TPM vehicle information screen on the DIC. See Driver Information Center (DIC) on page 4-27. Press set to relearn the sensors. The horn sounds twice to signal the receiver is in relearn mode and Tire Learning Active message displays on the DIC screen. 4. Start with the driver side front tire. 5. Remove the valve cap from the valve stem. Activate the TPMS sensor by increasing or decreasing the tire’s air pressure for 10 seconds, or until a horn chirp sounds. The horn chirp, which can take up to 30 seconds to sound, confirms that the TPMS sensor identification code has been matched to this tire position. 6. Proceed to the passenger side front tire, and repeat the procedure in Step 5. 7. Proceed to the passenger side rear tire, and repeat the procedure in Step 5. 8. Proceed to the driver side rear tire, and repeat the procedure in Step 5. 9. After hearing the confirming horn chirp, for the driver side rear tire, the horn sounds two more times to signal the tire learning mode is no longer active. Turn the ignition switch to LOCK/OFF. 10. Set all four tires to the recommended air pressure level as indicated on the tire and loading information label. 11. Put the valve caps back on the valve stems. |
