Old 11-07-2015, 09:13 AM   #1
Merc
In The Circle
Merc's Avatar
Official 2016+ V6 LGX 1/8 Mile Fast List
There are plenty of threads about 1/4 mile track times, but this thread is specific to 1/8 mile track times. The Official 1/8 Mile 2016+ V6 LGX Camaro Fast List list is divided into three classes for now.
Bone-Stock Includes completely stock car with zero performance changes. Cars must have stock exhaust, stock air intake, stock tune, stock tires, etc.
Bolt-Ons *without* Internal Engine Modifications or Power Adders. Includes cars with a modified air intakes, headers, ECU/PCM-tune, aftermarket clutch, non-stock rear gears, skinny front tires, etc.
Internal Engine Modifications and/or Power Adders Same requirements as above but for cars with Heads, Cam shaft, Nitrous, Turbo, Supercharger, etc.
The Rules:
Along with your time slip, you must post the details of your 1/8 mile pass... see the example below.
All time slips to be directly uploaded to Camaro 5 web site and not a third party photo storage service.
Example:
Car/Engine: 2SS/RS w/L99
Top Twenty Class: Bolt-Ons *without* Internal Engine Modifications
Tires used on the pass: Stock Pirelli ZR20 Summer Tires
Performance Mods (if any): CAI, LT's, DR's
R/T: .814
60': 2.014
330': 5.4490
660': 8.2898
660': 87.23mph
Name/Location of the track: Northstar Dragway Sanger, Texas
Date of pass: 9/25/2009
Weather conditions: (include Density Altitude, if known): 59 Degrees, 72% Humidity, Density Altitude: 424 feet, Relative Density: 98.77 % (Optional, but not required)
[insert the image of your time slip here]
Be sure to post your time slips. No slip = No update to the Top Thirty list without the slip.
Slips must be posted in this forum. Referring to slips in other forums doesn't count.
Potential qualifying times require posting of an image of the entire time slip: track name, date and run information. The only exception to this requirement is for tracks that cut slip in half.(if you need help, PM me.)
Track times will not be corrected for weather or track altitude.
Any one can submit his/her times to this thread.
Only one time slip per member will be included in a given class.
If two people submit times identical to the thousands of a second, the tie-breaker goes the higher mph.
It's a top thirty list, but the entire list can be viewed by opening the link.
Below is a example of what the posted time slip should appear like. The only exception to this rule are for those who run at tracks that cut the time slip in half to save paper. Updates to the fast list's will be IGNORED if the time slip is not POSTED correctly. If you don't have a high lighter handy simply circle the info with a pen. THX Merc
Modification Terms
1. Cam - Aftermarket Camshaft
2. Heads - Aftermarket Heads or Ported Factory Heads
3. CAI - Cold Air Intake
4. PTB - Ported Throttle Body
5. PI - Ported Intake
6. LT - Long Tube Headers
7. UDP- Under Drive Pully
8. Shorties - Short Length Headers
9. Exhaust - Includes any exhaust mods (muffler delete, axle back, x pipe, catbacks, etc)
10. Gears - Non Factory Gears
11. Converter - Non Factory Stall Converter
12. DRs - Street Legal Drag Racing Tires
13. Skinnies - Performance Racing Wheels
14. Slicks - Performance Racing Drag Tires (non street legal tires)
15. Tune - Non Factory Tuning
16. W/R - Weight Reduction (removing parts to decreased weight and increase performance).
(1) Bone Stock Camaro 2016+ V6 LGX M6
https://docs.google.com/spreadsheets...it?usp=sharing
(2) Bone Stock Camaro 2016+ V6 LGX A8
(3) Camaro 2016+ V6 LGX Bolt On's Only
Old 12-07-2015, 06:19 PM   #2
Merc
In The Circle
Merc's Avatar
Old 02-21-2017, 08:35 PM   #3
ItzGrimzy
ItzGrimzy's Avatar
Drives: 2016 Camaro RS 1LT w/ aFe CAI
Car/Engine: 2016 Camaro RS w/ 3.6L LGX
Tires used on the pass: Stock 245/40R20, blackwall, all-season, run-flat tires
R/T: .6744
60': 2.2874
330': 6.1129
660': 9.2103
660': 75.98mph
Name/Location of the track: Showtime Drag strip, Clearwater, FL
Date of pass: 2/18/2017
ItzGrimzy is offline   Reply With Quote
Old 03-11-2017, 02:06 AM   #4
Merc
In The Circle
Merc's Avatar
Updated!
Old 10-23-2017, 12:14 PM   #5
Abrown3118
Drives: Summit White 2017 RS V6 A8
1/8th time
A8 Stock v6
Reaction: .2119
60ft: 2.1813
330ft: 6.0430
1/8th: 9.1641
MPH: 80.78
Abrown3118 is offline   Reply With Quote
Old 11-23-2017, 06:06 PM   #6
Merc
In The Circle
Merc's Avatar
Updated!
Old 05-14-2018, 09:42 AM   #7
MyneS
STORM
MyneS's Avatar
Drives: 2021 Satin Steel Metallic 2SS
A8 w Borla ATAK
Tires used on the pass:Pirelli Pzero street
Performance Mods (if any): Overkill Supercharger stage 2
Category submitted for: Internal Engine Mods
R/T...... .053
60'........1.871
330'............5.221
660'........... 7.997
660’ mph... 89.95
Name of the track:Bradenton Motorsports Park (provides half slips)
Date of pass:4/26/18
Weather: 76 degrees hot n humid
IG: nacol2012
Check out: The creation of STORM
American Authority Front Bumper, ACS Rockers, GM Dark taillights, ZL1 Carbon Fiber interior dash, Engine Bay “red hot” Dress Up, 6LE Skorpion hood, Borla ATAK w Xpipes (TRADED)
MyneS is offline   Reply With Quote
