07-11-2018, 03:48 PM | #99 | |
07-15-2018, 08:33 AM | #100 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
So if you want to be exact, use a measuring cup, put that amount of water into an old water bottle, and mark it. Use the bottle to put the trans oil into. Don't waste a good measuring cup and risk pissing off the wife
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
08-30-2018, 11:04 AM | #101 |
Drives: 18 1SS 1LE HyperBlue Join Date: Aug 2018
FYI - when Googling "Tremec Syncromax" I came across this article with some interesting perspective from GM and Tremec on the use of synthetic lube in the TR6060
https://www.powerperformancenews.com...eat-lube-hunt/ |
08-30-2018, 11:20 PM | #102 | |
Drives: Grandad's C2 L89 Join Date: May 2017
2018 ZL1 1LE sw/PDR
08-30-2018, 11:52 PM | #103 |
never gets to the TR6060. it ends with the TKO600
01-30-2019, 01:54 PM | #104 | |
Drives: ‘17 1LE, ‘17 BMW 340, ‘18 F-150 Join Date: Nov 2017
2017 - SS 1LE
2015 - 2SS, RS, NPP, 1LE - Sold |
01-31-2019, 06:46 AM | #105 |
Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
Nice topic!
Does anybody did a transmission flush on Zl1 A10? -guessing it’s a different fluid, -suppose it’s a little bit different ... I will appreciate kind of the same topic for an A10 ... |
03-13-2019, 05:35 PM | #106 |
Drives: 22 Convertible V8 LT1 Join Date: Feb 2019
Any guides for the V6 LGX ?
03-16-2019, 05:15 PM | #107 |
Long hauler
03-28-2019, 02:22 PM | #108 | |
Drives: 2016 2SS (M6) Join Date: Jun 2018
REVIVAL
BUT, depending on how thick the TR6060 likes its lube, dare I ask if better or more consistent results may occur using the Amsoil or Pennzoil due to their higher viscosity indexes than the Royal Purple Synchromax (remaining a more consistent viscosity through the temperature range)? These oils are thicker, and I'm not sure if the TR6060 prefers a thicker or thinner oil. The Royal Purple Synchromax tests as the thinnest of all the lubes shown, does anyone know if that's what it prefers? Not trying to reinvent the wheel here, though it may seem as such. Lol |
07-19-2019, 12:34 PM | #109 | |
Drives: 2016 Camaro 2SS M6 Join Date: Mar 2019
07-19-2019, 01:49 PM | #110 | |
I put it in my 2017 ZL1 and it made it way worse. Even after I quickly had the stock lube put back in, shifting is still more notchy and grindable than before I tried to "improve" it.
07-19-2019, 02:31 PM | #111 |
Drives: '19 2SS M6. Join Date: Aug 2018
Just changed to Redline D4.
Shifts feel more positive. Good improvement.
2019 2SS, Shadow gray, 6mt, NPP, Magneride, Bose.
09-09-2019, 01:31 PM | #112 |
Drives: 2017 ZL1 Join Date: Jun 2018
I called ams oil and they recommend their atf. Anyone run at the ams oil? They also didn't have a oil for the rear diff.
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
