Old 03-31-2022, 10:55 AM   #1
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
STEERING LOOSE AFTER HEADER INSTALL ???
Morning Team, I removed my steering linkage piece during my header install, then bolted it back is as normal, tightened it up with the same bolts, and now my steering has 1.5" for play side to side!!! i checked the shaft, and the bolts are tight, but there is play in the assembly, where the pieces slide into each other... anyone else experience this? looking for help with a fix.
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC
Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank
ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE
BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi
Old 04-01-2022, 02:57 PM   #2
SOCAL.M6.ZLE
Am i the only one?
Old 04-01-2022, 03:17 PM   #3
Trochoidal
Drives: 2017 Camaro 2SS A8
I’m not sure how much you’ll get from this thread since OP never followed up. It’s happened to others.
https://www.camaro6.com/forums/showthread.php?t=573092
Old 04-01-2022, 03:17 PM   #4
MightyBobo
MightyBobo's Avatar
Drives: 2022 VOM 2SS 1LE M6 Camaro
I mean, I hate to say it, but it sounds like it was reassembled improperly.
Take it apart again, re-check everything, re-connect.
2022 Vivid Orange 2SS 1LE ordered (BDQDHT, 1G1FG1R7XN0108251) - ETA 20220223
20211120 - 1100 --- 20211207 - 2500
20211208 - 3000 (TPW: was 20220103, now 20220124)
20211220 - 3400 (TPW: 20220110)
20220114 - 3800 --- 20220122 - 4300 (1LE Wrap Shuffle)
20220125 - 4B00 --- 20220129 - 4200 (Shipped! ETA: 20220223)
20220212 - 4800 --- 20220216 - 6000!
2024 Silverado EV RST First Edition on reserve, as well.
MightyBobo is offline   Reply With Quote
Old 04-01-2022, 03:19 PM   #5
MightyBobo
MightyBobo's Avatar
Freaking hate it when people do this btw, and don't follow-up. There's a special place in hell for them.
Old 04-01-2022, 03:22 PM   #6
Trochoidal
I agree.
When I did my install the shaft went back together with no issues. So I don’t really have a solution.
Old 01-06-2024, 09:30 AM   #7
atlbandit
Drives: 2017 1SS 1LE
Just posting this in case it helps anyone or saves them some time.
I reached out to the OP and he stated that when torquing the bolts, one was over-torqed and it broke or cracked the weld nut. He ended up getting a longer bolt and putting a physical nut on the end of that bolt and tightened it which resolved the issue.
In my case.. im not sure if i was just tired or what b/c i did the install by myself ...but my steering was loose b/c i installed one of the intermediate shaft bolts upside down (duh). Removed the bolt and reinstalled from the other side and torqued to spec... issue was resolved.
This I was an easy enough fix so I hope it saves anyone in the future a little time that may have the same issue.
atlbandit is offline   Reply With Quote
