dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 07-22-2020, 11:35 AM   #1
co14camaro
Drives: 2014 Camaro
Oil cooler adapter
Has anyone used one of these to fabricate an oil cooler kit for the lfx?
https://v8roadsters.com/product/lfx-...ilter-adapter/
co14camaro is offline   Reply With Quote
Old 07-24-2020, 06:55 PM   #2
navigation13
navigation13's Avatar
Drives: 2015 2LT/RS
I'm also curious about this too
navigation13 is offline   Reply With Quote
Old 07-24-2020, 07:05 PM   #3
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
i don't like this part
" offering minimal pressure loss across the oil system"
lemontwist is offline   Reply With Quote
Old 07-29-2020, 12:33 PM   #4
co14camaro
Drives: 2014 Camaro
I think that's just them saying it shouldn't affect anything. I really don't see any other way for us LFX guys to cool our engine oil? Only other thing I've found is using the OEM oil filter housing from an ATS with the oil cooler installed.
Old 07-30-2020, 05:52 PM   #5
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
That's why I got the ACS TL1 hood insert. I epoxy'd bolts into the holes in my hood so I can remove the water deflector in a matter of seconds. Even with the water deflector on, it still made a big difference. Alternative would be a 14-15 SS hood insert.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
DSX_Camaro is offline   Reply With Quote
