TireRack
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Tuning / Diagnostics -- engine and transmission
Old 02-10-2016, 03:35 PM   #1
GQ4Life
Drives: 2010 Camaro SS LS3
Aeroforce scangauge read flex fuel sensor E%
Will the gauge read gm flex fuel sensor and show ethanol percentage?
Added gm flex fuel setup and Jannetty tuned for ethanol
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline   Reply With Quote
Old 02-10-2016, 03:42 PM   #2
blake-b
blake-b's Avatar
Drives: 2009 ZR1
They can display alcohol percentage. I do not know if you have to use "their" sensor or if it can be any sensor. I suspect any sensor since it reads from the OBDII port.
Older versions of the gauge can be sent in to have the feature added. I do not know when they started adding the ability but in 2014, they were talking about coming out with it on their forum.
