05-04-2013, 05:52 PM | #1 |
Drives: 2013 2SS Join Date: Sep 2012
At what pressure will the tpms trip
Anyone know what the lowest pressure you can run without tripping the tire pressure monitoring system? I have a new camaro with lowering springs and it rides much nicer at lower tire pressures but was wondering how low I can go without tripping the sensors.
05-04-2013, 06:17 PM | #2 |
Drives: My wife crazy with my C5 usage. Join Date: Apr 2009
I think the low tire warning on the DIC comes on @ 32 psi, but don't quote me on that. I might me thinking of the onstar warning from the e-mails.
UNDER CONSTRUCTION......again......
05-05-2013, 12:18 AM | #3 |
Drives: 2011 1LT/RS A6 RJT SuperCharged Join Date: Mar 2011
I had a slow leak and my sensor tripped around 26psi.
Power is worthless without control. The 2nd protects the 1st.
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ |
05-05-2013, 05:54 AM | #4 |
Drives: 2011 camaro ls Join Date: Jul 2010
The Onstar reports give you a warning at 32LBS.
05-05-2013, 06:49 AM | #5 |
Drives: 2012 2SS Join Date: May 2012
Funny you should ask, on my way home this morning @29 psi right rear tire came in alarm
05-06-2013, 11:30 PM | #6 |
2012 Camaro SS
Drives: 2012 camaro ss Join Date: Jun 2012
Anywhere from 5-7 over or under the psi it's suppose to be at
_________________________
2012 IMB CAMARO SS |
