05-04-2013, 09:42 AM | #1 |
Drives: 2013 Camaro 2LT RS Join Date: Jan 2013
Green valve stem caps
I just bought a 2013 2LT/RS Camaro, love the car, and noticed all of the valve stem caps were green. Would this signify nitrogen gas was used to fill the tires? I have a local tire dealer that will put green valve stem caps on if you elect nitrogen gas when buying/installing new tires from them. Just wondering.
05-04-2013, 09:44 AM | #2 | |
Drives: 2010 SS 426 V8 M/T Join Date: Aug 2012
05-04-2013, 09:45 AM | #3 |
Raining Blood
Drives: 2014 SS Performance Sedan Join Date: Oct 2009
Yes, nitrogen.
Ordered 1/9/12 - Born 2/3/12 - Delivered 2/21/12 - '12 1SS/RS Summit White - TRADED.
2014 SS Performance Sedan #2974 - Red Hot 2 - S/R. & Spare. Built 01/09/14 #238 of 291 as configured |
05-04-2013, 10:00 AM | #4 |
Flying da helicopter
On our aircraft we use yellow stem caps to indicate nitrogen used in the tires......I'm sure the green means the same
05-04-2013, 10:44 AM | #5 |
Go with helium. Makes your car lighter.
05-04-2013, 03:27 PM | #6 |
Account not blocked
they use green caps to let you know the wheels have a tire pressure monitor system. I have them on my malibu, and cruze.
05-05-2013, 06:01 AM | #7 |
Drives: 2011 camaro ls Join Date: Jul 2010
I wish my Camaro had nitrogen; then my TPS wouldn't come on and off.
05-05-2013, 02:18 PM | #8 |
Not true. Green caps are supposed to indicate nitrogen was used to fill the tires.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
05-05-2013, 02:39 PM | #9 | |
Account not blocked
i understand they are "supposed" to indicate notrogen filled, but its not a given, as i have green caps on my cruze and malibu, neither of them were filled with nitrogen, hence the change in preasure when the temps change. |
05-06-2013, 11:24 PM | #10 |
2012 Camaro SS
Drives: 2012 camaro ss Join Date: Jun 2012
Not true. Green means nitrogen. Has nothing to do with you tire pressure monitor system. An yes, it's a GIVEN. The fact that someone didn't filled them with nitrogen means your dealer is an idiot. Go to a another dealer.
_________________________
2012 IMB CAMARO SS |
05-06-2013, 11:26 PM | #11 |
2012 Camaro SS
Lmao I'm sorry not trying to be a d!ck but this has me rolling. Ignorance at it's finest.
05-06-2013, 11:49 PM | #12 |
Drives: Black 2013 2SS/RS 1LE Join Date: Mar 2013
Just to throw a iron in the fire, the air that we breath is approximately 79% Nitrogen, the Oxygen content is approximately 20%, and 1% other gases. If "compressed air" has over 3/4 Nitrogen, is the 100% Nitrogen really that big of an advantage? Possibly a expert in tires can answer that question.
