03-21-2013, 04:12 PM | #1 |
Drives: 2013 2LT Join Date: Jun 2012
Poor design or workmanship ?
03-21-2013, 04:13 PM | #2 |
That should be no big deal just one bolt on each side. Good luck though.
03-21-2013, 04:20 PM | #3 |
Drives: 2011 Camaro Join Date: Apr 2012
Mine does that and so does every other camaro I've seen. I noticed it right away and went back to the dealer to check out the others and most had it sticking out at least a little bit. Annoying.
03-21-2013, 04:26 PM | #4 |
When you say most , that means some were not. Mine wasn't either when i picked up the car. I say poor design.
03-21-2013, 04:27 PM | #5 |
No problem with mine.
03-21-2013, 04:28 PM | #6 | |||
SoCal Mayhem
Drives: 2010 Camaro 1SS/RS Join Date: Aug 2008
http://www.camaro5.com/forums/showthread.php?t=42276
03-21-2013, 04:50 PM | #7 |
I don't think my problem might be the same as yours. The seam looks good except the last 1.5 inchs where there is no support.
03-21-2013, 05:34 PM | #8 |
Forever Pontiac
Drives: 2012 Black 2SS/RS Join Date: Oct 2010
Have had mine over 1 year and haven't had this issue...
03-21-2013, 06:17 PM | #9 |
Drives: SRT Yugo GT Super Sport with Manual Join Date: Mar 2012
03-21-2013, 08:35 PM | #10 |
NoJoken
Had the same problem with mine. Loosened the screw, re-aligned, and tightened down. Then, towards the tip I installed a small self tapping screw being careful not to run it through the outside of the car.I put this next to the screw that is installed from the factory. Two years and never have had a problem.
03-21-2013, 09:11 PM | #11 |
Wonderfully Awful Idea
O.P. out of curiosity do you hand wash or go through a automatic wash? If automatic I'm thinking the brushes are catching and pulling it out. Still it is a problem.
03-22-2013, 10:32 AM | #12 | |
Drives: GM Vehicles Join Date: Jun 2010
Brandon Chevrolet Customer Service
For information on the GM Privacy Statement, please visit http://www.gm.com/privacy-statement.html
03-22-2013, 01:45 PM | #13 |
Drives: Black with silver stripes 2011 2ss Join Date: Apr 2012
I had the same problem and it was fixed by the dealer.
Sent from my SPH-L710 using Tapatalk 2 |
03-22-2013, 11:18 PM | #14 |
Drives: '11 2LT/RS IBM Join Date: Jun 2011
Mine popped out on one side when I backed into my brother's car in the driveway. Only damage that happened other than chipping, not too noticeable so not a big deal.
