dave@hennessey
Old 07-05-2014, 01:57 PM   #1
paultheman2007
SWFLGENS
paultheman2007's Avatar
Drives: 2011 Camaro 1SS
Exhaust tips BLACK?
I got Flowmaster Outlaw Catback and the Tips are black what is the Best thing to clean them they are suppose to be stainless steal.?
SWFLGENS on facebook.
paultheman2007 is offline   Reply With Quote
Old 07-05-2014, 03:27 PM   #2
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
Apc and water with a microfiber should do it unless it's really baked on. In which case I'd use #0000 steel wool to break up the carbon then polish the tips out.
[B]
CamaroDreams07 is offline   Reply With Quote
Old 07-05-2014, 03:33 PM   #3
Ryanbabz71
Ryanbabz71's Avatar
Drives: 2018 Hyper Blue 1SS 1LE
A small section of clay bar will do the trick too
Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic
Car Build: http://www.camaro6.com/forums/showth...0#post10049680
Old 07-07-2014, 08:50 AM   #4
AbsoluteMayheM
LongTimeLurker
AbsoluteMayheM's Avatar
Drives: 2011 SIM 2SS/RS Convertible L99
Once you eventually get them clean, just soap and water each wash will work after that.
Sent from my iPad using Tapatalk HD
2011 2SS/RS
AbsoluteMayheM is offline   Reply With Quote
Old 07-07-2014, 10:19 AM   #5
AmericanMuscleCars
Teenage Dream Camaro
AmericanMuscleCars's Avatar
Drives: A Visually Stunning Camaro
Depends on how bad it is, first I soak it with SCG APC if its bad enough and let it soak, then i get my rim bucket and grab the microfiber, if that doesn't work then I go to the foam applicator pad that is used for wax. If that doesn't work than I go to the steel wool, if that doesn't work I cut the tip off and call it a day. Be sure to use a good sealant on it and you won't have to do anything but use a soapy microfiber next time.
White shoes at the black show
AmericanMuscleCars is offline   Reply With Quote
Old 07-07-2014, 12:08 PM   #6
CamaroDreams07
Drives: Slow V6
What is your justification for the foam applicator?
[B]
Old 07-07-2014, 01:42 PM   #7
AmericanMuscleCars
It's just another step I use before a more aggressive step. It has some cutting properties to it more than a wet microfiber and less than the steel wool when use with pressure
Old 07-07-2014, 09:24 PM   #8
Fish-man
Drives: too many to say!
I painted my tips low gloss black... now it always looks normal
Fish-man is offline   Reply With Quote
Old 07-07-2014, 09:33 PM   #9
CCMADONNA
CCMADONNA's Avatar
Drives: 2014 SW 2SS/RS
after you get them all clean, wax them whenever you wash your car - it'll make it easy to keep clean and polished. i did this for eight years on my Solstice GXP and well…..
CCMADONNA is offline   Reply With Quote
Old 07-07-2014, 09:36 PM   #10
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
Originally Posted by Sammyll View Post
GTFO you spamming ass hat
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 07-07-2014, 09:39 PM   #11
Edzo
Edzo's Avatar
Drives: 2013 Camaro SS and 63 Impala
Ya, what the f#$K was that? Hopefully I didn't get a virus.
Edzo is offline   Reply With Quote
