12-13-2011, 05:08 PM | #15 |
Camaro Addict
Drives: 2010SS/1995 Z28/2005 CTSV/2007 TBSS Join Date: Jan 2007
Just look under the dash at where the clutch pedal connects and you'll see the culprit. Removing that spring was the best mod I ever did. Smooth as butter now...
http://www.camaro5.com/forums/showpo...0&postcount=17 |
12-13-2011, 05:08 PM | #16 | |
Emerald Coast Camaros
Drives: '12 2SS/RS LS3 GBA Join Date: Sep 2011
Muffler Delete, Cold Air Inductions intake, Technostalgia Sequential LED Tail Lights, Vmax CNC Ported TB, RX Catch Can, AAC LED Interior Lights (Aqua)
12-13-2011, 05:09 PM | #17 |
Drives: 2011 Camaro 2LT RS Convertible Join Date: Jul 2011
Mine is the smoothest clutch I've ever driven, hands-down.
Summit White Black Leather 3 Pedals Build Date: 06/27/2011 Purchased: 07/30/2011 Title Received: 08/15/2011 1984 Camaro (3rd Gen.): Traded: 1987 "Meet the new boss. Same as the old boss." |
12-13-2011, 05:09 PM | #18 |
Zippy Lemon #109
Drives: 2010 SLP ZL575 #109 Join Date: Oct 2011
It's a bone stock ZL575..so, lowered, Maggie, axle-back exhaust..."from the factory"
2010 SLP ZL575 #109
12-13-2011, 05:11 PM | #19 |
Drives: 2011 1SS M6 Green 1993 Custom Eldo Join Date: Jul 2011
I agree. I'm used to it now but it sure is different than any other setup I've ever had. Over 40 manuals in my life. My 66 and 67 Vettes (both big blocks) had friendlier clutches.
12-13-2011, 05:13 PM | #20 |
I bleed green
This is what happens when people complain. Some weenies complained about smooth clutches that required too much effort, so engineers design the "compound bow" clutch that screws everyone. (my opinion)
2011 2SS/RS LS3. Delivered 4/18/11. Solo Axle-back with J-pipes and quads, 35% tint, Yellow trim kit, Showstopper sidemarkers, babied garage queen. 2006 Silverado 3500 6.0, 1993 Pontiac Bonneville SSE |
12-13-2011, 05:14 PM | #21 | |
Guardians Of The Night
Have a lot of guys done this? It just makes the return a bit smoother or what?
2013 ZL1 Crystal Red Tintcoat, Stock...for now
1968 SS/RS 396- being resurrected. 2011 SS LS3-Cammed, bolt-ons.(SOLD) |
12-13-2011, 05:16 PM | #22 |
I bleed green
No, but a lot of guys have had the clutch pedal stick to the floor during aggressive driving, so i'm kind of afraid to remove it. What i've read is that at high rpm, the design of the clutch can lead to a partial engagement, which may be why the spring on the pedal is there.
12-13-2011, 05:19 PM | #23 |
Uhh yeah, i may leave mine in too ha... its really not that bad, most of my shifts are smooth, however I do have a problem with the shifter as if sometimes it feels rough going into second or third. Like there is something stopping it, and im afraid to slam it into gear and break something! thoughts?
12-13-2011, 05:22 PM | #24 |
Boosted Moderator
As with any hydraulic operator, there are o-rings or skirt seals that provide a seal for the fluid. As the operator passes in and out of the body it picks up particulate material and carries it into the cylinder...
The heat is understood... And between the heat and micro-particulates, the fluid thickens and makes operation of the clutch different... This is also how brake fluid gets contaminated... Which is why a "sealed" system needs to be flushed periodically...
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
12-13-2011, 05:25 PM | #25 | |
Drives: Sold: 2011 2SS/RS Join Date: Dec 2010
Also, the notchy gate issue for 2nd and 3rd gears has been duly noted all over this board. It has to do with the design of the syncros. If you want to know more, just do a search on grinding--I hear it's worse in some cars than others, particularly in the early LS3's. Edit: All the 4th gen guys will remember the T56 trans issues as well. The trans mount seemed to be especially weak, so there were plenty of manual 4th gens with bobbing shifters after the mount gave way. And, they almost always grind gears going into reverse |
12-13-2011, 05:31 PM | #26 |
Zippy Lemon #109
I suspect you're right. The funny thing is that I'm coming from a factory 600 HP Viper and that clutch was linear as could be and not much harder to depress if at all.
2010 SLP ZL575 #109
12-13-2011, 05:33 PM | #27 |
Chief Many Camaros
Drives: A paid off Camaro!!! Join Date: Mar 2009
Ariat's work great, my Justin's just don't cut it though. Who would of thought, dang country boys driving Camaros in boots.
504hp/478tq Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac |
12-13-2011, 05:36 PM | #28 | |
Vrooom Vrooom
Drives: Camaro 2011 black LS Join Date: Apr 2011
I still believe that the camaro transmission is a pos. |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Transcript of Camaro ZL1 Q&A Webchat with Chevrolet | Tran | Camaro ZL1 Forum - ZL1 Specific Topics | 42 | 12-22-2017 04:42 AM |
Gran Turismo 5... No Camaro? | 5thGenOwner | 5th Gen Camaro SS LS LT General Discussions | 111 | 12-06-2011 10:06 AM |
Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW | camarojoe | Dealer Camaros for Sale | 2 | 05-24-2010 05:58 PM |
GM memo to dealers | Moose | 5th Gen Camaro SS LS LT General Discussions | 41 | 02-04-2010 07:33 PM |
Answeres to questions I have stumbled on | dieseldave24v | 5th Gen Camaro SS LS LT General Discussions | 13 | 02-23-2009 06:56 PM |
