TireRack
Old 06-15-2017, 10:32 PM   #1
camarohead
camarohead's Avatar
Drives: 2010 ss rs ls3 red-white rallys
Expectant shop cost for installing lowering springs
Just started researching on lowering my car and wanted to get the latest opinions. Wanting just springs and looking at BMR "1 or "1.2, eibach kit and the Pfadt. Also, what am I looking at cost wise for a shop to install these?
Is a all wheel alignment necessary for just a "1 inch drop? Thanks.
eps cam 226/234 lsa 113+2, bfe 1 7/8 headers, rotofab cai, katech oil pump, 444 rwhp, 411 rwtq, eps tune, Blanchard performance install
camarohead is offline   Reply With Quote
Old 06-15-2017, 11:02 PM   #2
pabloss
pabloss's Avatar
Drives: 2010 camaro ss
Yes you will need an alignment.i paid 300 for the installation and alignment
pabloss is offline   Reply With Quote
Old 06-16-2017, 07:21 AM   #3
camarohead
camarohead's Avatar
Dang, that's pretty cheap. I figured it would be more than that. Thx
Old 06-16-2017, 07:25 AM   #4
camarohead
camarohead's Avatar
Think I have decided on the BMR springs. The 1 or the 1.25. Which height seems the most popular?
Old 06-16-2017, 10:06 AM   #5
jrhagen
Drives: Camaro
Get coil overs. You can set any height you want.
jrhagen is offline   Reply With Quote
Old 06-16-2017, 11:21 AM   #6
BMR Sales
BMR Sales's Avatar
Drives: Race Car
Yes, you will need an Alignment. The 1.25" are our most Popular Springs
Old 06-16-2017, 08:52 PM   #7
camarohead
camarohead's Avatar
Thx...will be ordering soon.
Old 06-17-2017, 08:05 AM   #8
camarohead
camarohead's Avatar
Now looking at the level 1 package from BMR with the sway bars. Should I ante up and go that route?
Old 06-17-2017, 08:45 AM   #9
KillboyPowerhead
Drives: 2015 Z/22
If you're planning to do sway bars I highly suggest getting the 2012+ OEM rear lower control arms and drop-links and switching to the 2012+ outboard mount rear bar. The arms and links are relatively cheap even from a dealer and fairly easy to install. As for the bar you can get an OEM 1LE (or ZL1 - same bar) bar or go aftermarket such as BMR or JPSS, etc.
Overkill/Self Tuned; Mace Camshafts; K&N Typhoon Cold Air Intake; Ported 80mm Throttle Body/Intake Manifolds/Manifold Spacer; Solo Performance High-Flow Cats, Cat-back Exhaust; Vitesse Motorsports Throttle Controller; Elite Engineering E2 Catch Can; BC Racing BR Coilovers; JPSS Delrin Radius Rod Bushing Inserts, Sway Bars; Pegasus Aluminum Rear Cradle Bushings, Camber/Caster Plates; Z/28 Toe Links, Trailing Arms, Upper Control Arm Bushings, Rear Shock Mounts
KillboyPowerhead is offline   Reply With Quote
Old 06-17-2017, 01:54 PM   #10
camarohead
camarohead's Avatar
Thx for the info.
Old 06-18-2017, 07:15 AM   #11
Strider044
Strider044's Avatar
Drives: 2015 2ss/rs Commemorative edition
I paid zero and just did it myself two weeks ago with a jack and two jackstands. I would say if you are somewhat mechanical you should be able to take your time and complete it in a weekend. Great experience and with the savings I was also able to throw on some ZL1 sway-bars.
2015 2ss/rs Commemorative Edition - DynoSteve Tune, NPP, Hotchkis sport springs 19110, Zl1/1LE rear swaybar, VR-DRX CAI, VaraRam VRX-93, Z28 spoiler
Strider044 is offline   Reply With Quote
