TireRack
Old 12-13-2016, 08:13 AM   #1
JERRYwss6
JERRYwss6's Avatar
Drives: 2011 rjt Camaro SS
Maggie tvs2300 users get in here!
Magnuson tvs2300 What is your set up and how much power did it put down?
JERRYwss6 is offline   Reply With Quote
Old 12-14-2016, 11:21 AM   #2
SannerRacing
SannerRacing's Avatar
Drives: 2010 1SS RS IOM
Forged 416 ls3
Jack shaft Maggie with RDS spacer ,over driven coged rear,10% over driven balancer 8 rib spinning a 3.1 pulley making 13 psi at peak.
Trick flow heads
CMS stage four cam on e85
697rwtq and 748hp on a mustang dyno and on a dyno jet it reads about 65 more horse.
And now the TB is to small and the snout doesn't flow enough air lol
Forged LS3 416ci, Maggie TVS2300 @ 13lbs boost, McCleod twin disc clutch, GForce 1320 nine-inch 389 gear ratio, Hurst line-lock, 750 whp 700 wtq
SannerRacing is offline   Reply With Quote
Old 12-14-2016, 01:30 PM   #3
cc-rider
Drives: 2010 Camaro SS
Originally Posted by SannerRacing View Post
Forged 416 ls3
Trick flow heads
Trickflow heads. Nice. I'm lusting after these. Do you have a before/after dyno of these or did they go on with a bunch of other mods? Wondering how much power they were worth. Nice thick decks on them for handling big boost.
cc-rider is offline   Reply With Quote
Old 12-14-2016, 08:33 PM   #4
fleebag
fleebag's Avatar
Drives: Moneypit
Last time on Dyno before I fixed the belt slip(went to 10rib)
610 @ 9lbs
OD rear cogs, 10%od crank, 3.3 front
850's w twin pumps
Since that dyno I now run a nw102 and I run Teds tune and it holds 14lbs and duty cycle is right at 60%. Oh and it's an LSX 376. But I may be swapping to turbo just not sure yet as I love the instant boost.
fleebag is offline   Reply With Quote
Old 12-15-2016, 12:50 AM   #5
SannerRacing
Don't think they made a big difference as far as power but it could be because
the TB is to small now. But the stock heads started pushing water at 14lbs so it was either fix the old or buy new. And I don't think price wise after having the old heads fixed and ported was much different than just getting TF heads. And I did bump up in CI plus went with a larger cam and it only made 50 more horse. So hard to tell but I can tell you it wants a whole lot more air.
Old 12-15-2016, 06:47 AM   #6
swiftkart
swiftkart's Avatar
Drives: 2010 SS/RS LS3 M6
JRE Tuned stock bottom end and stock heads, rough idle cam, kooks headers, Maggie Max 2 (1/2" spacer, NW 102, ported tub), OD rear cog, 10% OD crank, 3.4 pulley, 13.5 psi, LC32 Billet Inlet, LC32 double wrap pulley bracket, Forced Induction Chiller, CAI, Squash twin pump system, E85, 843rwhp/803tq Dyno jet, Mustang -43rwhp.
swiftkart is offline   Reply With Quote
Old 12-15-2016, 07:37 AM   #7
SannerRacing
How much of a gain do you think the 102tb and LC32 inlet would get me? And I forgot I got the ported tube to.
Old 12-15-2016, 07:44 AM   #8
SannerRacing
610 @ 9lbs
850's w twin pumps
That's what I love about the PD stuff the instant Torque. The new vengeance 2.65 has got my eye for the bump up. Then I think my block would be pretty much maxed out to wear you got plenty of room for more boost. Never ends lol
Old 12-15-2016, 09:39 AM   #9
swiftkart
swiftkart's Avatar
NW102= 25rwhp
LC32 Inlet= 65rwhp/tq, it's not just a big opening, it's well thought out and has a ramped floor that feeds the rotors, see pictures in my garage, I sent H-E a picture and he copied it and is trying to act like it's something he came up with to unsuspecting customers, but he didn't, it's left coast 32's concept and it works.
Old 12-15-2016, 09:46 AM   #10
SannerRacing
NW102= 25rwhp
Yep I've seen it, Joes new shop is only about 45min from here. But now with this vengeance blower coming out think I'll hold off putting two more grand in to this thing for a 100hp!
Old 12-15-2016, 10:53 AM   #11
swiftkart
swiftkart's Avatar
Well not quite 2k, more like 1.4k lol (well that was when I got my NW102/LC32 Inlet)
The inlet makes the blower way more efficient (pulls all the way to 7k with no drop off) and the throttle response picks up a bunch also.
Old 12-16-2016, 10:29 AM   #12
ABM Camaro
ABM Camaro's Avatar
Drives: 2013 ZL1 A6 Camaro
Man I need one of these bad, but im just hoping to 500RWHP
2013 ZL1 Camaro A6. ARH Headers, K&N intake, Tuned by Tampa Tuning
2014
V6 Camaro bolt ons and E85
ABM Camaro is offline   Reply With Quote
Old 12-16-2016, 11:01 AM   #13
Blue70SS
Blue70SS's Avatar
Drives: 10 LS3 2SSRS IOM,21 ZLE Wild Cherry
Most recent dyno from 7/30/16: (no dyno fans & on portable Dynojet)
elevation in Laramie, Wyoming is 7165 and boost was about 14 psi... so about 17.5 at sea level
Pull one with "109" shot: 836.8 RWHP, 924.13 RWTQ with dyno pull over at 5900 rpm (seemed like rev limiter, but was N20 shutting off at 140 mph due to my track settings)... so probably about 860 RWHP on this dyno day
Pull two with "109" shot: 842 HP, 900 TQ ~20-25 less on each with heat soak
Pull three with no N20 and heat soak: 677 HP, 656 TQ
Setup is 10/14 rib pulley system, double pinned jackshaft pulleys, 16% rear overdrive, 8" balancer (6% OD), and 2.95" front jackshaft pulley, 1/2" RDS thermal blower spacer with direct port injection N20 (flowed for basically 50/100/150/200/250/300 shot sizes), ceramic coated and ported tub, Nick Williams 102mm throttle body, Rotofab CAI, 2" ARH ceramic coated headers, 3" Corsa exaust to 2.5 around differential, 1 gal SC coolant reservoir, Torq dual pass heat exchanger with dual fans, insulated coolant tubes, squash twin fuel pumps, 1000 cc IC injectors, 91 octane fuel, LPE 9.5" diff with 3.73 gears, CF driveshaft.
Most recent change is "151 shot" (weird #s because it's a bench flowed system), 2.75 front jackshaft pulley, and changed from a Rotofab CAI to a CIA brand - since the newer hood was preventing the Rotofab from sealing. Expecting about 925 HP & 1000 TQ on next dyno prior to refreshening the block for doing some "mile" events. Boost with the 2.75 pulley has been about 16.5-17 depending on weather, with elevation at 4984' .... so about 19-19.5 at sea level.
Current stock cubes block has 50k semi-hard miles on it since it was forged at 5k miles. Has almost 50% leakdown on cylinder 8 when cold.... so definitely more power to be had, plus tune is much more conservative than it used to be.
Planning on Trick Flow heads, 3.42 rear gears, and a large SC coolant reservoir in the trunk and dial things in after the break in period.
LPE 650+,IOM Pearl White Rallys
860 RWHP 924 RWTQ,TVS2300 10/14 OD 2.75/NW 102mm,RDS/FLOWED "109" SHOT/LPE NCC
NLP spoiler/GM splitter/Torq HE-fans/oil coolers/IC1000cc
Squash twins,GT9,Coil Covers,Mats,Pedals/ADM Gauges,Race Scoop/Trunions
DDS CVs,Carbon F DS/RPM L6/LPE 9.5 3.73/Pedders HD bushes,align kit
RB 2-piece rotors,S/S Lines,Hawk HPE Pads/Forgeline SP3P/Weld RTS
Ceramic ARH 2" LT/3" X-pipe,Corsa Touring/BMR TA,Toe,LCA,DS Loop
StreetSlayer BC3/MTI Shifter-Trans mt/Hotchkis CB/Monster CC/SJM LineLock
PFADT Coil Overs,Sways,Links,Mounts,SF Bushes,Camber Kit
LPE Brotherhood
Blue70SS is offline   Reply With Quote
Old 12-16-2016, 04:06 PM   #14
Warhorse
Warhorse's Avatar
Drives: 2011 Syn Green Camaro
Don't want to hijack OP's thread. We can take this through PM if necessary.
Are you using a dedicated fuel cell with your direct injection setup? and what fuel pressure are you using? I'm just about to complete new LSx build with direct port and still on the fence with which boost referenced fuel pressure to go with for nitrous fueling. The fuel jets get very small when your at a 250 shot and less. Would not take very much trash in fuel to cause a disaster. Low pressure fuel ex. 7 to 10 lbs would at least require jet sizes almost twice that of high pressure 43-58 lb fuel,
Have you ever looked at how small a 10, 12, 14 etc. size fuel jets is? Scary!
New Build
5th Gen Camaro, 430ci LSx, Ported Mast 280's, E85 Flex fuel, ID1300's, Squash return, TVS 2300 w/Nitrous Outlet 250 Shot Direct Port, Nano, LPE 10/14 Rib, OD Crank, OD Rear, 2.8" upper, RDS Plate, NW102, 5" Intake, 2" ARH, PATC Built A6, BMR 15" Brake Conv. w/Drag Suspension, Front QA1 DA's, Weld S76 beadlocks & "V" Series fronts. STILL 1k too heavy!!!
Warhorse is offline   Reply With Quote
