TireRack
Old 01-18-2014, 09:58 PM   #1
Camaro Dude
Camaro Dude's Avatar
Drives: ‘13 1LE
Removed Rear Chevy Bowtie, and Found This Under It
I decided to go ahead and take off the rear center chevy emblem, to make way for an other look I'm experimenting with.
This is what I found as seen in the pics.
Basically, I found an itty bitty little dent, smack right in the middle of where the chevy emblem used to reside. Looking at it straight on, you can't see the dent. Only in the angle that we are looking at right now, you can see it.
Car is brand new, hardly driven, now sleeping for the winter. Not really sure at all what to say about this, to be pissed, or brush it off..
Has anyone ever seen anything like this before??
Not sure if it can be fixed painless "dent wizard" way, since it's right where the crease is, OR if I should make a claim at the dealer?
Camaro Dude is offline   Reply With Quote
Old 01-18-2014, 10:23 PM   #2
elarson5757
Obsessed and Loving It...
Drives: 2013 1LE-SS
They gave the fixture that applies the bow tie a hell of a push or banged it in when applying. If it bothers you I'd make them fix it. If not and you don't notice it I'd leave it alone. They may also try to say you did it trying to pry off the bow tie depending on the quality of your dealer.
elarson5757 is offline   Reply With Quote
Old 01-18-2014, 10:41 PM   #3
Shortbus
Shortbus's Avatar
Drives: 88 IROC Z28
Isn't the Chevy Bow tie put on in the factory? Are they all like that? Maybe that's the shape of the trunk in order to give the bow tie a flatter surface to bond to in the middle.
LB9 Ohv V8 220 @ 4400 290 @ 3200 TPI 9.3:1 305/5.0 IZ (w/man trans)
Shortbus is offline   Reply With Quote
Old 01-18-2014, 11:24 PM   #4
13blackLS
13blackLS's Avatar
Drives: 2013 camaro ls; 2005 rx8
Mine had a similar ding when i removed mine...lookes smaller than yours though and hardly noticeable to me, so i didnt bother worrying about it...
13blackLS is offline   Reply With Quote
Old 01-18-2014, 11:29 PM   #5
Jason P
Jason P's Avatar
Drives: 2011 2ss
Changed my rear bowtie.....no ding
2011 2ss Ram twin plate ceramic clutch, Texas speed 418 LS3 235 /243 .621 / .624 cam, ported and polished heads with dual springs,magnum push rods, Hotchkis race pack, Stainless Power long tube headers with no cats, Magna Flo competition exhaust, lpe fuel pump, magnuson supercharger with overdrive and port matched blower plate, IW 8 rib pullies, AEM meth kit, id 850 injectors, 3 bar map, halltech cai, zl1 rear diff
Jason P is offline   Reply With Quote
Old 01-18-2014, 11:48 PM   #6
Camaro Dude
Drives: ‘13 1LE
Actually it does bother me, because I was really planning on putting two S S's in the middle there. No, not the one Sparks sells, you know, the one that is one piece and sits on a plate. Rogers at Emblemspro, was in the process of designing me custom separate S S pieces, hence my taking off the Chevy Bowtie tonight, in slow preparation of the separate S S emblems arrival date.
Now this happening.
Old 01-18-2014, 11:52 PM   #7
2012-1822
2012-1822's Avatar
Drives: Black ZL1
I popped mine off. Didn't pay attention to it because I had a body color painted one ready to go right back on.
I thought I remembered some of the early Camaros coming with a hole back there, a little one under the bowtie. Not really sure about that, just thought I remember a post about it. Like just the early 2010's or something.
Check out Alabama Camaros, for Camaro enthusiasts all around Alabama https://www.facebook.com/groups/1739...group_activity
2012-1822 is offline   Reply With Quote
Old 01-18-2014, 11:55 PM   #8
moserbe
moserbe's Avatar
Drives: 2012 Camaro SS
No dings in mine either when I took it off to put the black vinyl and the SS emblem on.
moserbe is offline   Reply With Quote
Old 01-18-2014, 11:57 PM   #9
Camaro Dude
Drives: ‘13 1LE
Yes, the early ones had a couple of pinholes I think. Mine being a 2013, obviously did not.
Old 01-19-2014, 01:18 PM   #10
Camaro Dude
Drives: ‘13 1LE
$40-$50 to fix that dent with my contact, I think I'll go that route. Making a claim at the dealer certainly not worth the effort. Just the hassle and my time is definitely worth more, although the principle of the matter could be used as an argument here I'm sure.
I mostly posted this thread up, so that others can pay closer attention to theirs.
I was also curious if this is a common occurrence or not? Already, post#4, 13blackLS observed similar dent.
Old 01-19-2014, 01:27 PM   #11
All Star
I'm an Engineer
All Star's Avatar
Drives: 2019 Camaro 1SS 1LE
Send a message via AIM to All Star
I see nothing that makes the dealer responsible to fix this, outside of the goodness of their hearts. The bowtie was functioning as intended from the factory.
All Star is offline   Reply With Quote
Old 01-19-2014, 01:35 PM   #12
CamaroTom
CamaroTom's Avatar
Drives: 1/70 2013 BRM 2SS RS 1LE NPP NAV
There's some guys who have removed thier 1LE hood wraps and have had paint defects. The dealer fixed those so I don't see why they wouldn't fix this. But I would rather have my own dent guy do it rather than let the dealer touch it.
CamaroTom is offline   Reply With Quote
Old 01-19-2014, 01:35 PM   #13
Ron71
Drives: 2013 Camaro 2SS RS Convertible
Another option is to put a Sparks SS emblem there. I bought one for the front and rear to replace the bow ties. They look great in my opinion.
Ron71 is offline   Reply With Quote
Old 01-19-2014, 01:39 PM   #14
Camaro Dude
Drives: ‘13 1LE
True true, but my custom S S emblems from Roger are on their way anyways, so I have no choice now but to fix this dent now. Unless the dent removal dude tells me that he can't do a 100% fix, due to location or whatever else the case may be, although I have a good feeling about this.
Worst case scenario, then yes, I'll have to install a "one piece" SS emblem like the one you suggested, since that would essentially cover it all up, just like the bowtie did before .
