05-04-2012, 04:30 AM | #1 |
Drives: 2012 LS Join Date: Mar 2012
shift points
hey guys, as you can tell, i have a v6 2012 manual. been trying to look if anyone has tested out the best shift points between gears. for gas mileage i use between 3-4k but im interested for speed purposes. feedback please.
05-04-2012, 04:55 AM | #2 |
Let's go Rangers!
For gas you should be between 2-3K.
05-04-2012, 06:06 AM | #3 |
Book Learner
Drives: 2010 Camaro 2LT, 1999 Tahoe 2Dr. Join Date: Aug 2011
I have found that for both economy and the easiest rev match between gears is shifting around 2.5K especially from 1st to 2nd.
05-04-2012, 11:13 AM | #4 |
Drives: transformer Join Date: May 2012
h
05-04-2012, 11:16 AM | #5 |
h
05-04-2012, 11:18 AM | #6 |
h
05-05-2012, 09:58 AM | #7 |
Drives: 2012 2LT/RS Join Date: Nov 2011
Is this chart actually suggesting that the v6 camaro will go 243mph?
05-05-2012, 06:47 PM | #8 |
Awesome info. Thanks.
05-05-2012, 09:59 PM | #9 |
I'd say that chart is pretty much accurate. I don't take her all the way to red line when going for speed, but I get pretty close.
Although you know that since you have an LS you have a speed limiter set at 118mph, so for speed purposes you'll barely use fifth and not even touch sixth unless you get a tune to take the speed limiter off and some different tires(since the speed limiter is there because the tires are only rated up to 118mph). And, as a couple others have said, for gas mileage you wanna stay closer to 2k rpms. |
05-07-2012, 03:58 PM | #10 |
epic. you guys are awesome. i appreciate it so much.
05-07-2012, 04:08 PM | #11 |
Drives: Tacoma/2LTRS Join Date: Jul 2011
i switch gears a 2k rpm and cruise at 1.5k for saving gas is this ok ..i have a 2012 v6 2lt
05-07-2012, 05:25 PM | #12 | |
Drives: 2010 camaro 2SS LS3 Join Date: Aug 2011
like really? my rc car could be geared to go 500. will it? hell no.
stage III cam, 4.10's, custom CAI, suede headliner
461 RWHP, 422 RWTQ |
