Old 09-18-2015, 03:51 PM   #1
bigwayne3000
Drives: 2011 Camaro LS
Need to vent about the PITA it is to change out front struts
Can someone explain to me why GM (maybe it is every manf.?) is using a bolt that you have to hold with vice grips while also using a wrench to get the nut off? I am referring to the one that holds the tie rod(maybe?) in place, NOT the main 2 holding the strut to the wheel. There is a nut that has no back so the only way to hold it is in the same location you need the wrench to loosen the nut...
Also, maybe it is just my car but on the driver side front, the nuts holding the strut to the wheel hub assembly (I have no idea proper terms) 1 is metric and 1 is standard, WHY!? Why would you use 2 different kinds?
bigwayne3000 is offline   Reply With Quote
Old 09-18-2015, 05:04 PM   #2
Orange 2010 Camaro
Orange 2010 Camaro's Avatar
Drives: 2010 2SS/RS Camaro
Please post a couple of photo's so I can see EXACTLY which bolts you are referring to.
All the best,
Orange 2010 Camaro
Orange 2010 Camaro is offline   Reply With Quote
Old 09-18-2015, 05:10 PM   #3
IMPERIALBLUE2SS
Drives: 2010 imperial blue LS3 M6 2SSRS
My friend you need to invest in an impact gun..
IMPERIALBLUE2SS is offline   Reply With Quote
Old 09-18-2015, 05:11 PM   #4
Synner
Drives: cars
You're talking the sway bar end link, it needs to rotate so yes you hold one side and unbolt the other. If I recall from stock it had an allen head insert on the end, wasn't hard.
Synner is offline   Reply With Quote
Old 09-18-2015, 05:12 PM   #5
Synner
Drives: cars
If you enjoy destroying struts.
Old 09-18-2015, 05:53 PM   #6
bigwayne3000
I have an impact gun but this bolt, isn't a standard bolt that has a hex side that you hold while loosening the nut... the bolt is perfectly flat on the one side so you have to hold the side that has the nut with a pair of pliers while using a wrench to get it off, really makes no sense..
Old 09-18-2015, 05:57 PM   #7
bigwayne3000
All the best,
Orange 2010 Camaro
It isn't #'d but it is the very top bolt in this picture. It is completely flat on the one side so you're forced to hold it with pliers while also using a wrench to un bolt it...
Old 09-18-2015, 05:57 PM   #8
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Hope you're not saving the top strut retaining nut for last bigwayne!
You've gotta hold the strut center in place with a Torx key(size 50 I believe) while loosening the 24mm bolt with a box wrench.
It takes a 7mm wrench to hold the swaybar bolt in place while you remove the nut with a 13mm box wrench (maybe 15mm- it's been awhile).
Finally the two bottom nuts should be the same. If they're 24mm, remember a 15/16" wrench or rachet will do the trick as well.
Ventmaster is offline   Reply With Quote
Old 09-18-2015, 06:05 PM   #9
bigwayne3000
Yea, I learned on after the first one not to leave the top nut for last.... then on the 2nd one I didn't realize I undid it as much as I did and the entire thing fell down when I was taking out the last bolt on the bottom... Job is done but that 1 little bolt on each side were pains, by your explanation I didn't do it properly which is why it was a pain I suppose...
Old 09-18-2015, 06:11 PM   #10
bigwayne3000
Ventmaster: also the bottom 2 bolts were the same on the passanger side then on the driver side, one was metric and the other standard. Don't remember sizing but they were definitely different and it made no sense... I also haven't had anyone work on the car that would explain maybe losing a bolt and them replacing it with different size so no idea what happen there..
Old 09-18-2015, 09:13 PM   #11
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
The clevice bolts on mine are the same size.
Also, yeah, for the sway bar end link, 7mm wrench and a 15mm I believe. 7mm will hold it still while you loosen the sway bar nut.
It's no worse on this car than any other McPherson strut car.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 09-19-2015, 01:41 PM   #12
Ventmaster
Ventmaster's Avatar
LOL- It's reassuring Wayne to hear of someone else having some difficulty. I've read here about so many guys flying thru these installs, and while I eventually accomplish my goals, I always end up with a few abusive epithets and busted knuckles before I'm finished. And usually a trip to the hardware store for a new tool!
Old 09-19-2015, 04:38 PM   #13
bigwayne3000
Thanks guys... it is just so weird that on 1 side the clevice bolts are of different sizes, makes no sense!
Old 09-20-2015, 09:24 AM   #14
LSX Camaro
Master ASE, GM, LSX Tech.
LSX Camaro's Avatar
Drives: 2010 Camaro SS
There is not a standard bolt on the entire car from the factory. All are metric.
2010 2SSRS A6, Custom Pat G. Cam, WCCH Cylinder Heads, Kooks Headers/Exhaust, BTR Valvetrain, Fluidampr 25% UDP, All Engine ARP bolts, Flex-a-lite radiator/Trans cooler, Yank converter, PFADT Suspension, ADM Race Intake/Scoop, Torq tow hook, CFD auto shifter, Dynojet AFR gauge, Aeroforce scan gauge, Brake Performance rotors/pads
Prothane bushings, ZL1 wheels, spoiler, Z/28 wickerbill, 1LE Aero/Suspension Package, Anderson Composites COPO Carbon Fiber Hood, LED lighting, Elite Catch Can, Improved Racing oil pan baffle, crank scraper, windage tray
480 RWHP 452 RWTQ + Nitrous Express 150 Shot
LSX Camaro is offline   Reply With Quote
