TireRack
Old 09-18-2015, 01:47 PM   #1
NJBourne23
Master of Nothings
NJBourne23's Avatar
Drives: 2010 Chevy Camaro 2LT/RS
Upgrading my V6 brakes
So i bought some SS Brembos and looking to upgrade my brakes in the near future. I know that I have to order new rotors and I will probably just cut the dust shields since I heard it's a pain in the as* to get them off and replace with SS Dust shields. Are there benefits to upgrading the dust shields? Are there any other things I would need besides new brake lines and rotors? Want to make sure I have everything before I'm halfway through and realize i'm screwed.
Thanks
NJB
2010 Chevrolet Camaro 2LT/RS
NJBourne23 is offline   Reply With Quote
Old 09-18-2015, 01:51 PM   #2
sbubbaklein
sbubbaklein's Avatar
Drives: early 2011 Camaro convertible
new banjo washers will insure proper bleeding.
Early 2011 LT Convertible, ZL1 bumper, hood, side skirts, belly pan and wheels, Truecarbon ECF hood extractor, K&N CAI, Elite catch can, Big Worm Bow Tie emblems, Jacfab bracket, Vitesse TC, BMR strut brace, BMR tunnel brace, NPP exhaust
sbubbaklein is offline   Reply With Quote
Old 09-18-2015, 01:51 PM   #3
NJBourne23
Master of Nothings
NJBourne23's Avatar
Also, does anyone recommend a particular rotor brand? I'm not a fan of drilled because they get filled with crap but slotted isn't off my radar
Old 09-18-2015, 01:52 PM   #4
NJBourne23
Master of Nothings
NJBourne23's Avatar
Yeah i can't reuse the washer right? Banjo you say? I shall look into these
Old 09-18-2015, 07:34 PM   #5
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
New banjo washers will come with the new lines! OEM rotors are just fine, Stainless steel brake lines would be recommended though. Make sure that you order Brake lines for the SS with BREMBOs though. People are going to tell you that you'll need new mounting bolts, I reused mine and everything is fine, LOC-tite.
Eddiefuzz is offline   Reply With Quote
Old 09-18-2015, 09:14 PM   #6
Destructo09
Drives: 2010 CGM Camaro 2SS/LS3
I bought Centric C-TEKs for the front of my SS, they work just fine for track and the street.
2010 2SS
BMR 1" Springs
Koni Orange struts/shocks
1LE rear sway bar
SRP Racing Pedals
Hurst Billet short shifter
Square tire/wheel setup
Elite Engineering Catch Can
Stainless Power longtubes/highflow cats
K&N Typhoon CAI
RPM Motorsports of Garner, NC dyno tune (421 RWHP)
Destructo09 is offline   Reply With Quote
Old 09-18-2015, 09:54 PM   #7
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
The bolts are $8...is it really worth the risk?
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats.
KaBoom1701 is offline   Reply With Quote
Old 09-18-2015, 11:44 PM   #8
Destructo09
I assume we're talking about caliper bolts?
I've re-used mine twice now, red loctited them and been on track twice, no issues. I've done a full autoX season on "re-used" caliper mounting bolts too.
I'm not a fan of this torque to yield thing, lots of manufacturers don't even use them on cars with the same calipers.
2010 2SS
BMR 1" Springs
1LE rear sway bar
SRP Racing Pedals
K&N Typhoon CAI
Old 09-20-2015, 10:21 AM   #9
derek1387
Drives: 2015 1LS Red V6
Anyone have the banjo washer part number,
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Dream Gear Mobile Audio
Thanks to Will @ Overkill Motorsports, Jason @ JacFab, Jim @ Ohio Speed, Brandon at Dream Gear, and the boys at Randy Curnow Chevrolet
5th Gen V6 Performance Facebook Group
derek1387 is offline   Reply With Quote
Old 09-20-2015, 05:48 PM   #10
VTSummit
Consistently inconsistent
Drives: 2015 2LT Summit White
I don't- but the local hardware store had brass washers that matched perfectly for 9 cents each. You ARE installing SS lines, right?
Thanks to MRR, I have some SWEET wheels! Thank you!
2015 2LT Ported TB, Ported intake, JACFAB intake spacer, Borla exhaust, IPF 91 tune, Complete 1/LE suspension, Brembo brakes, Goodridge lines, Elite catch can, CAI with Thermo-wrap, 275/40-20 x 10's all around, Z/28 spoiler, GM splitter, Alpine/Polk stereo with AudiControl interface.
VTSummit is offline   Reply With Quote
Old 09-20-2015, 06:08 PM   #11
sbubbaklein
O'reily has lots of different sizes, take an old one by.
http://www.oreillyauto.com/site/c/se...ts=20&sortBy=1
Old 09-20-2015, 06:57 PM   #12
derek1387
SS Lines as in, SS Camaro? Or Stainless Steel lines?
Sponsors:
Overkill Motorsport
BCS Auto
JacFab Machining
APDEG
Old 09-20-2015, 07:26 PM   #13
JMT
JMT's Avatar
Drives: 2013 1LT
I cut my dust shields and haven't had a problem.
JMT is offline   Reply With Quote
Old 09-20-2015, 08:25 PM   #14
VTSummit
Preferably both- but SS Camaro lines are required to run SS brakes. V6 brake lines no workie on the Brembos.
