10-30-2023, 03:58 PM | #1 |
Drives: 2017 2LT RS on 20's, manual Join Date: May 2016
'Engine Oil Low' with 25% Oil Life Remaining
I have a manual 2017 LT v6 (bought brand new from the dealer) and I'm getting an 'Engine Oil Low' indicator popping up randomly the last few days - even though it's showing 25% Oil Life Remaining.
I checked the dipstick and the oil was all the way at the very bottom of the dipstick... so I put in 1 Litre / 0.22 gallons of Pennzoil synthetic high mileage (I have 140,000 km / 86,992 mi on it) and now the oil level is normal. This is actually the second time this has happened now. Anyone know what could be causing this? I normally drive it easy in Touring mode - with only occasional brief periods of aggressive higher RPM shifting in Sport mode. Majority of the time I shift at no higher than 3,000 rpm. |
10-30-2023, 04:05 PM | #2 |
Oil at bottom of dipstick... does that mean below the low level line? If so, then you need more than 1 qt.
Obviously you need to start monitoring oil consumption. If you were burning that much oil, I suspect you would notice the blue smoke and you might even get a check engine light from fouling the O2 sensor. I suspect a leak. I would put some cardboard under the car overnight and see if you pick up any drips. Also, check out some other threads here which show the dipstick and how much oil you need to add. I usually fill to the top line and then it's easy to see if I am losing oil because if it drops below that line then it's leaving the engine somehow. |
10-30-2023, 04:05 PM | #3 |
My GMC will drop a litre in about that % range using the computers oil change counter, it has about 145,000 km. I will say my catch can collects some of it
10-30-2023, 04:22 PM | #4 | |
Yes... as in I could barely see ANY oil on the dipstick at all! After I added 1 litre (0.88 quarts) it was to the top line... so definitely enough. I then drove it for 10 mins, and parked it for 3 hours before checking the dipstick again while nice and cold, and the dipstick was still measuring oil up to the top line. I have also never had the 'check engine' light come on for an O2 sensor. I have so far done all of my oil changes at the GM dealership. I am wondering if they are using subpar quality oil (i.e. non synthetic etc.) as a sneaky cost-cutting measure. Dealerships are constantly trying to find ways to scam people it seems. |
10-30-2023, 04:24 PM | #5 |
Drives: 2018 Hyper Blue Metallic SS 1le Join Date: Oct 2023
oil life and oil level are two totally separate things. your oil life could be 98% and still be 2qts low, you need to figure out why it's losing or consuming oil...
10-30-2023, 04:26 PM | #6 |
2020 Shadow Gray 2SS
1 Liter = 0.264 US Gallons...
1 Liter = 1.056 US Quarts...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
10-30-2023, 04:40 PM | #7 |
Drives: Chevy Camaro 2021 ,rs, v6, manual Join Date: Feb 2022
See if you have oil in the air intake tube. If I go over half way on the high- low mark the oil go to my intake till level gets below half quart low. You should change oil at %25 imo because the lgx only pulls vacuum from the air intake tube.
B6 dampers, x pipe, mbrp axel back
10-30-2023, 04:54 PM | #8 |
Drives: 2023 Chevrolet Camaro 2SS 1LE Join Date: Jan 2020
This. Oil level low has absolutely NOTHING to do with oil LIFE.
Current: 2023 2SS 1LE
Prior: 2016 Camaro 1SS 2007 Mustang GT 2008 Civic Si |
10-31-2023, 04:43 AM | #9 | |
Thank you Al Oppenheiser!
Twice?
Check your oil bi-weekly. Change it at 50% on the OLM. Quote:
If you're not going to change your own oil yourself, then at least check the dipstick BEFORE you drive off the shop lot. Trust, but verify. The other benefit of doing your own oil changes is sending samples to blackstone-labs for analysis. You can gain some insight into how your engine is running and oil condition vs. your driving habits. This information may or may not help guide you to improve your situation. Finally, if you're not using top-tier gas, switch. Loyalty programs like Shell's Fuel Rewards (plus stacked discounts from Tmobile, etc.) often make the cost same or cheaper than the low-bid dime-store garbage. That and/or higher octane may help with cylinder carbon control. Good luck |
10-31-2023, 07:06 AM | #10 |
Drives: 22 SS 1LE Join Date: Apr 2022
How many miles since your last oil change? Consuming a quart / liter over several thousand miles isn't abnormal for some engines, especially after getting up there in miles. Might need to check oil level every other fill up or as needed, and add some when you get about 1/2 way down on the dipstick markings.
10-31-2023, 09:28 AM | #11 |
Below links to photo of our dipstick. if "barely touching bottom," I would fill with 1.5 qt to get it to the top line. Take a photo of the dipstick with the oil level. Then do the same every 2-3 days to track loss.
https://www.camaro6.com/forums/showp...00&postcount=1 My comment about the O2 sensor throwing a code meant that I doubt you are burning a lot of oil. The rate of loss you describe would result in blue smoke plus odor, which I think you would notice. That much oil being burned off can foul sensors and damage catalytic converters. I think you have an old school leak. Last edited by ctrlz; 10-31-2023 at 01:49 PM. |
10-31-2023, 01:12 PM | #12 |
Drives: 2018 ZL-1 Join Date: Jan 2018
At 87,000 miles, your car could have developed any number of leaks and other issues. The computer caught the oil low situation - not you.
Have you looked under the hood? Under the car? Leaks are often easy to spot, unless the engine is covered in grime. You should probably go to the dealer about this. |
10-31-2023, 02:04 PM | #13 |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
For reference, my VW Atlas Low Oil warning light came on at 6,500 miles, down 1 quart. Coincidentally the day before my scheduled oil change. When I had the first oil change done at 10,000 miles, it was down a quart also.
Back in the day, I had a C6 CTF that was going through a quart every 600 miles or so. They swapped the engine in that car to take the original apart for inspection. I was told many years ago that for warranty to be performed, you had to be burning oil (assumes no leaks) at a quart every 1,000 miles. Not sure if that's true anymore as I'm not sure the car/truck would pass an emissions test.
10-31-2023, 02:27 PM | #14 |
Drives: '17 Camaro 2SS & '99 Camaro Z28 Join Date: Feb 2014
I think my 3.6L burned off about a quart of oil between changes, nothing more than that. How long are you going between changes?
Tags |
2017, 3.6l, engine oil low, oil life remaining |
