03-15-2016, 01:23 PM | #29 |
Destroyed by flooding
Drives: Wife's car Join Date: Mar 2014
Amsoil Signature Series and filter here. Oil sample came back in the normal range with a 7000 mile interval. Check out how Amsoil got into business.
03-15-2016, 01:53 PM | #30 | |
Captain Gingerbeard
Drives: 2012 IOM RS/SS 6MT Join Date: Feb 2013
I run Shell Rotella T6 5w40 in all my cars, all the time. Tried Royal Purple, but went back to Rotella.
Yes, it's technically a diesel oil, but it's got a good high amount of ZDDP in it, which is an excellent anti-wear additive.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads. Quote:
03-15-2016, 08:00 PM | #31 | |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
Diesel oil is more than just high ZDDP. It is also very high in detergent. Diesels need high detergent for their long change intervals and specific deposits diesel fuels create. Detergents are kind of the opposite of friction modifiers and anti wear additives. Detergents wash things away, those anti wear things try to stick and leave coatings... So they battle each other. Racing oils have no or very minimal detergents, but they are changed very often. The last thing you want in a race motor oil is a detergent. But it is very needed in a diesel oil that is going to be going monster miles before the next change. So I only put diesel oil in diesel trucks, but that is only my opinion. My street cars run Amsoil Signature Series. In the race cars I use Brad Penn in one and LAT in the other. |
03-16-2016, 05:52 AM | #32 |
Drives: 2011 Camaro 2LT/RS Join Date: May 2015
Since my engine is stock, with no mods whatsoever, I use GM Dexos 1 (5w30), which is what was in it from the factory, and keep it changed every 3,000 miles.
03-16-2016, 11:47 AM | #33 |
Drives: ‘13 1LE Join Date: Jul 2013
03-17-2016, 10:00 AM | #34 |
Drives: 2013 AGM ZL1 BELLA* Join Date: Jan 2011
Mobil 1... Have ran it in all my cars from camaros to trucks. I'm running a big cam and lots of boost in my ZL1 with no issues.
Roto Fab CAI, Roto Fab Big Gulp, Jokerz ported SC/Snout, LS7 TB ported, ATI Balancer, 28%(10") Lower Pulley, 2" Headers, No Cats,Forza 3way, E85 Flex Fuel sensor , ID850 injectors,, BTR Stage 3, Ron Davis HX, Mighty Mouse CC, APR Splitter, Aero Sports Concepts Splitter Kit, Showstoppers CarbonFiber wicker bill, MRR Wheels. 720rwhp/690tq on 93, 762rwhp E85.
2013 AGM ZL1 Bella* 2010 MGM Toyota Tacoma 2010 CGM SS (Traded) 1996 Black SS (Sold) |
03-17-2016, 11:10 AM | #35 |
"Mobil 1" works perfect for me too
03-17-2016, 06:54 PM | #36 | |
El Duderino
There are a few, really good, easily available full synth oils out there. I heard it said you can benefit by switching between some of these high quality oils each change. RP, Castrol, Mobile1, Amsoil ... etc. They are all different, and use different makeups of chemicals, detergents etc. So... by switching amoung several top brands, you get the benefits of all the oils and suffer less from any one particular drawback of a certain brand.
I have decided to utilize this oil philosophy because to me it sounds logical Not sure how it would effect a modified CAM engine as the benefits of the plan are only realized after many oil changes over 10's of thousands of miles. JMHO, YMMV. This video is interesting:
I bowl. Drive around. The occasional acid flashback.
03-18-2016, 08:01 AM | #37 | |
I use the LAT 20w50 synthetic racing oil in my drag car, which is a 540 BBC. Have also had really good luck with Brad Penn 20w50 in the drag car. Both of those oils do great for drag racing. LAT is one of the best when going with a really agressive cam and super stiff valve springs. Tons of anti-wear additives in the LAT. The only downside is the cost. In my 1LE with a stock LS3, I'm using Amsoil Signature series. Seems to do great on the the street. When I start doing track days with that car, I'll probably put in something with more anti-wear. Maybe the Zrod or Dominator or Brad Penn. |
03-18-2016, 09:46 PM | #38 | |
Counting down the days...
Drives: Black 2011 2SS/RS Join Date: Mar 2011
This is a pretty neat video done by Mobil-1. Yes, it is an import (BMW) and yes it is an inline 6 motor, but its pretty neat to see the lengths Mobil-1 went through to test their oil on the 1,000,000 mile test.
Tick Performance Custom Cam w/ support mods/BBK LT Headers w/ midpipes/Straight Exhaust/Airaid Cold Air Intake/ZL1 Driveshaft/ZL1 Differential/Hendrix Engineering Offset Bushings/ZL1 Axles/BMR Rear Subframe Bushings/BMR Toe Rods/Carlyle Racing 15" Conversion/Jannetty Winsheild Bottle Scoop/Forgestar 15x10 Beadlocks wrapped in Mickey Thompson Radial Pros
03-19-2016, 09:17 AM | #39 |
Drives: 2015 Camaro SS Join Date: Sep 2011
Mobil1 0w-40 and i'm cammed
2015 Camaro 2SS Cam/Heads/FBO 498/447 SAE |
