03-17-2016, 11:12 PM | #1 |
Drives: 2010 2SS/RS L99 IBM silver stipes Join Date: Dec 2015
Steering shaft. Can't get back on.......
So I installed my Stainless Works LT headers tonight. I had to take apart the steering knuckle. Now it won't give me enough slack to bolt it back up. Any ideas???
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough.... |
03-18-2016, 02:15 PM | #2 |
I didn't take the knuckle apart. I just unbolted it from the input shaft.
03-18-2016, 09:05 PM | #3 |
Lake Erie Monster
Drives: 02 Hyundai Santa Fe and 13 300 Join Date: Aug 2012
I used long wrench and a lot of patience.
Everything I say is to be taken as an opinion and not fact so don't get upset over words that spill out of my head.
GO CAVS! |
03-18-2016, 09:16 PM | #4 |
Drives: 2011 SS (Sparrow Spearer???) Join Date: Aug 2013
so you slid the top part off the input shaft correct? first, dont move the steering wheel. I also unbolted it and slid the top part off and moved it out of the way to install the headers. when i went to slide the top part back on, i notice the bottom part had rotated ever so slightly, that i could not slide the shaft back on. i grabbed a small crescent wrench, and ever so slightly rotate the input shaft on the rack, until the top part slid back on. be patient though and itll work out
Black magic woman, don't turn your back on me baby!
03-18-2016, 09:26 PM | #5 |
I am doing Stainless Power headers this weekend.
I did not take the steering shaft apart and was able to get the old manifold out. Hoping I don't need to take it apart to get the header in...
2011 2SS/RS Convertible, Victory Red, Roto-Fab CAI, Stainless Power 1 7/8 headers, No Cats, Straight piped, Bo White TB, ZL1 CONVERSION, CDC Roll bar and some powder coating and dipping.
03-18-2016, 09:32 PM | #6 |
the hardest part of taking the manifold out is those damn hard to reach bolts. I did have to undo the coupling though to fit the headers in. (ARH 1 7/8 btw) but it was a one man operation on jackstands.
03-18-2016, 09:54 PM | #7 |
So are we saying I still may have to separate the steering??? Ughhh.
03-18-2016, 10:13 PM | #8 |
Firefighter/Paramedic
Drives: RJT 2SS/RS M6 LS-3 Join Date: Aug 2009
Shouldn't have to disconnect anything except for oil dip stick. Factory exhaust manifolds with cats still attached slide out the bottom. Headers are installed through bottom of vehicle. Drivers side takes a little playing around steering shaft but it will go. I've installed about 20 sets, everything from Kooks to AR to SW etc.
FFPM73
03-18-2016, 10:19 PM | #9 | |
03-18-2016, 11:45 PM | #10 | |
Resident nomad
Drives: 2014 Summit White 1SS/1LE Join Date: Nov 2015
Sold:
2007 Z06 2002 Viper GTS/ACR 2003 Z06 1965 FFR Cobra 2012 Nissan 370Z ADM LSA Stage II, Roto-Fab CAI, Kooks LTH/HFC's, Phastek CC, ported TB, Mishimoto radiator and oil cooler, BC Racing ER Series CO's, JPSS 32mm Black Magic rear bar, JPSS front inserts, R1 Concepts Premier slotted rotors/Goodrich SS lines, Schroth ASM harness, MGW flatstick, Brey-Krause HB, Tuned by NicD, at Cordes Performance Racing. |
03-19-2016, 01:14 AM | #11 |
Thanks for the replies. I didn't think I would have to undo the shaft. Everything came out REAL easy. I did go from the bottom to install headers. The problem is the shaft itself is somehow stuck away from the input shaft I unbolted it from. It is lined up, but I can't get the shaft back close enough to slide over the input to bolt back on. I grab it with 2 hands and pull as hard as I can and it only moves maybe an eighth of an inch. It needs to slide up and over about and inch and a half.
