dave@hennessey
Old 10-31-2013, 09:19 AM   #1
StanTheMan
Drives: 2014 Camaro 2SS
What exactly is muffler delete? Advantages and disadvantages?
Hi guys,
Can somebody please clarify this for me? What exactly does this "muffler delete" mode entail? I know it makes the car sound louder but apart from that, what other advantages/disadvantages does it bring?
StanTheMan is offline   Reply With Quote
Old 10-31-2013, 09:26 AM   #2
40years
40years's Avatar
Drives: 2016 CAMARO 1SS Hyper Blue Met.
You also lose about 40 ugly pounds from the rear end of the car.
proud member "club elite" # 89
40years is offline   Reply With Quote
Old 10-31-2013, 09:27 AM   #3
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
louder and less weight, is about it. might gain a half horsepower. lol
Old 10-31-2013, 09:27 AM   #4
upflying
upflying's Avatar
Drives: '86 Monte Carlo SS
A disadvantage would be an unsolicited contact from a LEO.
upflying is offline   Reply With Quote
Old 10-31-2013, 09:29 AM   #5
SabotAndHeat
SabotAndHeat's Avatar
Drives: 2010 Camaro
A muffler delete is simply a straight pipe (some have new exhaust tips) that is put in place of the muffler after its been cut and dropped out.
Pro's- Better sound, weight reduction, better gas mileage, better high speed / RPM output
Con's- Low end torque is reduced slightly, but you'll make it up (and more) at the top of the power band.
If youre thinking about it....do it. It's one of the cheapest, easiest and coolest mods you can do. Also, on a stock SS it's not so loud that it'll piss off the neighbors.
SabotAndHeat is offline   Reply With Quote
Old 10-31-2013, 09:31 AM   #6
mat300z
Emerald Coast Camaro's
mat300z's Avatar
Drives: 2014 ZL1
Originally Posted by StanTheMan View Post
Hi guys,
one of the best and cheapest mods you can do!
mat300z is offline   Reply With Quote
Old 10-31-2013, 09:36 AM   #7
Green Machine
Always Workin
Green Machine's Avatar
Drives: 2021 Mazda MX-5
Please explain how deleting mufflers changes low end torque? Most of the exhaust restriction are from the cats.
Sent from the road.
2023 Vivid Orange 1SS 1LE 6MT
Arrived 8/31
Purchased 9/3
2018 1SS 1LE, HyperBlue Metallic (Sold)
2014 1SS 1LE, Black, Twin Turbo (Sold)
Green Machine is offline   Reply With Quote
Old 10-31-2013, 09:38 AM   #8
Goo
Goo's Avatar
Drives: Cayman S
Not a true straight pipe... You still have cats and resonators, so it isn't as loud as you might think.
It does sound as good or better than most axle back after-market.
All in all, the only advantage is it sounds better... and disadvantage is deceleration popping (if you don't like that... I for one count that as another advantage...)
Goo is offline   Reply With Quote
Old 10-31-2013, 09:42 AM   #9
ka1
ka1's Avatar
Drives: 2011 2SS
It's not nearly loud enough for that.
ka1 is offline   Reply With Quote
Old 10-31-2013, 09:43 AM   #10
ka1
ka1's Avatar
Drives: 2011 2SS
All this. Best $50 I ever spent in life.
Old 10-31-2013, 09:47 AM   #11
Dznts
Anabolic Connoisseur
Dznts's Avatar
Drives: Sold - Blown Camaro 2SS/RS LS3
Throw some long tube headers on and that problem is solved
Dznts is offline   Reply With Quote
Old 10-31-2013, 09:49 AM   #12
SabotAndHeat
Drives: 2010 Camaro
Sent from the road.
Most, isnt all. Restriction is a variable statement. A 3 inch straight pipe might present lots of flow for a 4 cylinder ricer. But a 3 inch straight pipe might be restrictive to a big block Chevy with a 600 c.i. blower on top. With that being said, anything that collects heat, creates exhaust turbulence, etc in the exhaust system...creates restriction. The muffler does create restriction, even if not most of it.
Engine breathing is a static target of balance between backpressure and flow. That is...until hardware is added or deleted, then the scale moves. At the low of end of the powerband, backpressure is a little more beneficial for a quick take off.
With a delete, the normal back pressure builds a little further in the RPM band because there is less restriction.
P.S. It's exactly why some Corvettes have a dual mode exhaust. At more than 25% throttle and higher than 3500 RPM's the exhaust bypass mode opens...allowing for the Corvette to have the best of both worlds.
Old 10-31-2013, 09:50 AM   #13
snaphappy
snaphappy's Avatar
Drives: 2011 Camaro Convertible SS2/RS LS3
Some folks have said muffler delete is too loud for their taste. Just a heads up. I cut mine off and put on axle back from Solo with J pipes. Love the sound. No matter what you do it will sound better than stock!
snaphappy is offline   Reply With Quote
Old 10-31-2013, 09:53 AM   #14
Bell040
Bell040's Avatar
Drives: 2SS/RS - Black - GFX
Where did you hear this?
Better flow = more torque
Ordered: 10-13-08
Built: 3-30-09 (#1691)
Recieved: 6-12-09
Blacked out, Cammed (Lunati Voodoo 233/245, .578/.598 @114°, +4°), ARH LTs, VR OTR CAI, Cutouts, and lots of other fun mods.
Bell040 is offline   Reply With Quote
