11-25-2016, 07:45 PM | #1 |
Drives: 2011 Camaro 2SS Join Date: Apr 2014
Eibach Pro Plus kit Install for $750????
I just purchased an Eibach Pro Plus kit and asked the local race shop for a quote on install of the swab bars/springs. They quoted me $750, seems a little steep to me. I looked around the site but couldn't find anything. Any help would be awesome!
11-25-2016, 07:59 PM | #2 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
Seems steep. Most shops are $100/hr this to me is a 3-5hr job depending on experience/skill (not much needed this is something a diy guy could tackle at home with basic tools in the driveway)
11-25-2016, 08:13 PM | #3 |
Yeah I felt like it was steep. They have sway bars/springs at 6.1 hrs/$125 hr. Wish I trusted myself enough to do them myself.
11-25-2016, 08:49 PM | #4 |
bmr lists their spring install time at 2-3 hrs and f/r sway bar kit install time at 3-4 hrs (surprised me didnt think it took that long) so 6hrs is not as bad as I thought, id shop around anyways its not a highly skilled install pretty basic
11-25-2016, 10:50 PM | #5 |
Drives: 2015 Z/22 Join Date: Aug 2015
With an impact drill the sway bars can be done in a couple of hours in the driveway even if you haven't done them before; when I did mine I had no idea what I was doing and managed to do them in a few hours with just hand wrenches (those torque to yield nuts and bolts are a real pain in the ass without power tools; you can't hand-tighten/loosen them until they're about to fall off). For the first time doing springs you could probably manage all four in ~four hours with all of your tools at the ready and a bit of research beforehand.
If you're not too confident to do it yourself then $750 might be worth the cost (hopefully that includes timing the bushings and alignment). |
12-19-2016, 10:15 PM | #6 |
Drives: 2010 Camaro 2SS RS Join Date: May 2016
That is way too much for springs & sway labor on a 5g Camaro. I found that most of these shop charging this amount are not taking into account that our cars do not need spring compressor to remove spring from the shocks. A local shop pretty known charges 280$ plus 50$ for alignment
12-27-2016, 10:23 AM | #7 |
quick chime in i got the same kit put in for 350
"How do u keep it under the speed limit? YOU CANT HAHAHAHA" |
12-27-2016, 04:03 PM | #8 |
USA-1
So, if you have hands and aren't injured somehow tackle this yourself.
Seriously, search on Youtube how to do it and just follow the instructions.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete |
Tags |
eibach, installation, springs, swaybars |
