Old 07-08-2015, 03:03 PM   #1
HurstPerformance
HurstPerformance's Avatar
Drives: 2013 Camaro SS and 2016 Camaro SS
Hurst Stage 1 Suspension Kit for 2010-2012 Camaro SS
Part # 6320000
Application:
Fits 2010-2012 Chevrolet Camaro SS Models.
Description:
The Hurst Stage One Suspension Kit is an excellent choice for firming up the handling of your car and giving it that "Just Right" stance. This suspension kit will lower your vehicle approximately one inch (depending on the application), and also increase the roll stiffness. These two small changes close up that fender gap, lower your center of gravity for improved handling and braking, and keep body roll to a minimum. From the very first drive, you will notice a more neutral balance to the vehicle, precision turn-in capability, and increased cornering grip. Through careful design and rate tailoring, the Hurst Stage One Kit accomplishes all of the above while still being street friendly - truly a "win-win" situation.
Features and Benefits:
-High Performance Handling
-"Just Right" Stance for the perfect muscle car look
-Daily driver / Street friendly
-Performance swaybars dramatically reduce body roll
-Lower Center of Gravity - Will lower the vehicle approximately 1 inch (depending on application)
-Improved Aero Efficiency = Small Gain in MPG
Part Attributes:
Use Location: Suspension
Sway Bar Material: High Strength Steel
Sway Bar Diameter (in): 1.14(Front)/1.14(Rear)
Sway Bar Color / Finish: Hurst Gold Powdercoat
Spring Uncompressed Length (in): 11.500(FRONT)/10.375(REAR)
Spring Uncompressed Diameter (in): 6.375(FRONT)/5.560(REAR)
Spring Rate: 134 LBS/IN (Front)
Spring Position: Front & Rear
Spring Maximum Compressed Length (in): 3.689(FRONT)/4.089(REAR)
Spring Maximum Compressed Diameter (in): 6.375(FRONT)/5.560(REAR)
Spring Color/Finish: Hurst Gold Powdercoat
Rear Sway Bar Type: Hollow
Progressive Rate Spring: 230-425 LBS/IN (Rear)
Position on Vehicle: Front/Rear
Package Quantity: 1
Package Contents: 4 Springs, 2 Sway Bars, & Hardware
Mounting Hardware Included: Yes
Item Grade: High Performance
Front Sway Bar Type: Hollow
Constant or Variable Spring Rate: Constant(FRONT)/Variable (REAR)
Coil End Type (2): Pigtail
Coil End Type (1): Pigtail
Bushings Included: No
Bar Size (in): 0.545(FRONT)/0.610(REAR)
For additional questions, please call our sales department at 707-544-4761.
HurstPerformance is offline
Old 02-16-2017, 10:58 AM   #2
HurstPerformance
Due to these kits being discontinued, we offering them at an incredible price through our eBay Store. Don't miss out on a chance to get a great deal on a great kit.
Old 02-16-2017, 02:24 PM   #3
Nutro
Nutro's Avatar
Drives: 2011 2SS Synergy Green
I wish they were true 1" drop springs, I would buy them.
L99 With a Maggie
Nutro is offline
Old 03-01-2017, 01:02 PM   #4
dcmock
dcmock's Avatar
Drives: 2010 loaded 2SS L99 tuned OBX long
killer deal
Ya I just scored this kit for 190.00 free shipping. Can't beat that!
2010 2SS/RS Loaded, L99,OBX longtube headers, gpi ss1 camshaft, 821 heads, hp oil pump, dod delete, iwis pro series timing chain, trunnion upgrade, RDP dynosteve tuned, Cold air intake with scoop, 3:45 GEARS, BMR diff bushings, Hurst stage 1 sway bars
dcmock is offline
hurst, lowering, springs, suspension, sway bar
