06-21-2023, 08:37 AM | #1 |
Drives: 2012 Camaro 2SS/RS Vert LS3/M6 Join Date: Aug 2021
Window Re-Learning on a vert
I did the negative battery cable add on in the trunk. Does anyone know the process to re-learn windows on a vert? is it the same as a hardtop?
06-21-2023, 09:11 AM | #2 |
It don’t come easy.
I would think so. Give it a shot. Hold down button extra second or two before releasing and going up. If I didn’t hold for the extra seconds, didn’t seem to want to work.
06-21-2023, 09:54 AM | #3 |
Do you need to do both drivers windows? or just the main one? Ive tried just holding the buttons, but not disconnecting the plug at the door, and it didnt seem to work.
Key off all windows up, door closed, turn key into ACC position, get prompt on DIC, main window down, hold for 4 seconds, main window up, hold for 4 seconds. and nothing happens. what am i missing? |
06-21-2023, 10:17 AM | #4 |
Try all this I just found. Good luck, hope you get it fixed.
https://www.camaro5.com/forums/showthread.php?t=70683
06-21-2023, 12:14 PM | #5 |
3P171 USAF Combat Arms
Drives: 2013 SS/RS Join Date: Jul 2021
Tim, mine asked after I reconnected the battery.
416ci LS3/Vortech V7/Built 6L80
994.4 RWHP 793.8 RWTQ |
06-21-2023, 12:36 PM | #6 |
Mines asking. just not STOPPING asking....after I try the procedure. Do i need to close and open both front and back window? What am i missing here....and Wayne, Ive tried that first one, and its not working. Guess Ill try to unplug that connector and try again edit one more, do i need the top up maybe??
06-21-2023, 02:25 PM | #7 |
Tim, yes the top has to be up for the indexing to take hold so that’s probably why it’s continuing to ask even though you keep putting the windows up and down.
06-21-2023, 03:02 PM | #8 |
well shit....no wonder..thanks man!
06-28-2023, 09:40 AM | #9 |
yep....Top up and it worked!
06-28-2023, 05:32 PM | #10 |
06-29-2023, 06:03 PM | #11 |
Drives: 2015 Topless Btch RS Join Date: Mar 2016
On my 2015 it tells me which window in order
06-29-2023, 06:55 PM | #12 |
Funny, it only asked me for the drivers! all the others are working as well.
