07-08-2022, 04:07 PM | #1 |
Drives: 2018 Grandsport Corvette Join Date: Apr 2022
BEST I PHONE MOUNT
Whats best way to mount your I phone
2022 Orange ZL1
4/07/22 7-01-22 Past 2018 Gransport 2018 GT Premium 2009 ZO6 2008 Z-51 Vette 2001 Stroked/ blown C-5 2001 SS 1998 SS vert. Garage 2020 Range Rover V-8 2021 Ford F-150 Platinum Powerboost |
07-08-2022, 05:14 PM | #2 |
Drives: 2019 Camaro 2SS Vert Join Date: Apr 2020
ProClip ... they currently still have their 4th of July sale. Use code "HAPPY4TH"
07-08-2022, 05:24 PM | #3 |
Drives: 2021 Crush ZL1 1LE Join Date: Oct 2009
Ditch the rubber thingy in the rear console that is too small for anything since the first flip phone. I cut up a piece of dense foam about an 1/2 thick and put a long piece of velcro over it. Drop my phone into the mostly useless black hole of a cell charger, foam on top so it is higher than the sides of the black hole, and then a band of velcro that runs over the foam and down to the carpet on each side. Used a bit of the soft side velcro to attach the foam to the strap.
Works great, but still might use the Dremel to trim up some of the left over plastic bits in the sorry excuse for a cell phone charger. Glad they didn't use these clowns in the engine and suspension departments.
2021 Crush ZL1 1LE Last edited by gotroost; 07-08-2022 at 05:26 PM. Reason: typo |
07-08-2022, 08:47 PM | #4 | |
D3RPZILLA
Pro clip
Website: z1lla.com | YouTube: youtube.d3rpzilla.com YouTube Playlists: Performance Mods | Interior & Exterior Mods | Other Mods |
07-09-2022, 07:18 AM | #5 |
Thanks, just ordered Pro-clips
2022 Orange ZL1
07-13-2022, 07:48 PM | #6 |
Drives: 2018 2ss redline Join Date: Sep 2019
still works excellent
https://www.camaro6.com/forums/showthread.php?t=583992 |
09-04-2023, 07:57 AM | #7 |
Drives: 2023 Camaro Convertible 2LT Join Date: May 2023
I have a ProClip for iPhone X/XS/11 Pro for sale... here is the link.
https://www.camaro6.com/forums/showt...0#post11355070 |
02-10-2024, 07:59 PM | #8 |
Drives: Chevrolet Camaro 2SS 1LE Join Date: May 2023
I just went with a magsafe flat charger, an acrylic disc about the same diameter and ~1/8th in thick. Some 3M adhesive and did this. I plugged the charger into a usb slot in the console and tucked the wire out of the way. The charger sits just a tid bit above the plastic edges of the console so when my iphone 15 pro max sits on the charger the outer edges provide a bit of stability. The magsafe holds the phone very well, even under some quick lateral moves.
The only thing I have to be aware of is when I grab my phone it can pull the little rubber mat out unless as im grabbing the phone I push with a finger on the mat to separate the phone from the charger. |
02-15-2024, 08:47 AM | #9 |
Electrical Engineer
Pro Clip is pretty nice and what I use. You order the phone holder separate from the base mount. It rotates to landscape or portrait mode.
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
