08-23-2015, 06:31 PM | #15 |
Drives: no camaro Join Date: May 2014
Thanks, feeling better about saving a few bux and adding 2010's to my shopping list
08-23-2015, 07:10 PM | #16 |
Drives: 2011 2SS/RS LS3 Join Date: Jan 2015
The suspension can be converted to FE4 with some rear arms and swaybars. Really easy. The front strut towers on '10/early '11 did not have the mount for the oem STB but there are plenty of AM solutions. Since you want leather you're looking at a 2ss and the early '10s didn't have park assist and none of them had the HUD, both of which you would see on a '11 2ss. '10s also had some brake squeal which was addressed later with added weights to the calipers.
2011 2SS/RS LS3 Rotofab CAI/scoop/washer - FE4 conversion - Pfadt ZL swaybars - BMR endlinks - Hurst short shifter - RKSport spoiler |
08-23-2015, 08:01 PM | #17 |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
You can always add the HUD like I am going to do in the future. I have the parts and the accessories guy at my Chevy dealership said he can install it, but I want some more power first lol
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
08-24-2015, 08:25 PM | #18 |
Drives: 2010 imperial blue LS3 M6 2SSRS Join Date: Aug 2013
My 10 is a late build, I have the parking sensors and the upgraded pads. Bought it with 2k on the odometer. Have 15k on it now rock solid. No leaks,or problems.
08-24-2015, 08:36 PM | #19 |
I JUST bought my 2010 2SS/RS two weeks ago. 28,450 miles, Flowmaster, K&N CAI, window tint, from a BMW dealer for $23,480, 60 day warranty. I am so happy with it its ridiculous.
08-24-2015, 08:37 PM | #20 |
I dont have brake squeal, I dont see any weights. No HUD stinks, but didn't bother me until I realized the newer ones had it.
09-01-2015, 04:28 AM | #21 |
Drives: GMC Sierra AT4 Join Date: Jul 2013
If you get a good price on a 2010 and you don't need techy stuff from the start then that's what you should get. I haven't seen any real issues out of 2010 models other than bad brake squeal, cracked dash board above passenger airbag which is a common problem in 2010, and if you remove the rear spoiler expect to find chips in the paint where the spoiler was. Just remember 2010's are 5-6 years old now, i'd check both Autocheck and Carfax reports and take it for a good test drive before you buy it so it gives an opportunity for anything bad to show up during the test drive.
2020 GMC Sierra AT4 6.2L
WTB - 2010 Camaro 1SS or 2SS, Aqua Blue Metallic, A6 |
09-01-2015, 03:51 PM | #22 | |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
Just checked now and there's an SS 2010 automatic for 22k even, with long tube headers, k&n filter, throttle spacer, rohana 22" wheels, kenwood touch screen radio, and an SLP programmer. If you're getting used definitely don't settle for a V6. Only issue I know of for the 2010s is the dash board cracking, which you can cover with a dash mat. Also heard lots of heater core problems, I think there is either a recall or TSB for it. |
02-13-2016, 01:01 PM | #23 |
Drives: 2010 Camaro SS (RS LS3) Join Date: Dec 2015
sorry for bumping such an old thread guys. But i would like to ask if anyone knows a decent vin decoding (equipment) website?
I tried using all the ones that shows on google but none shows the actual options, and most of them shows wrong specs :S |
02-13-2016, 08:25 PM | #24 |
drinks virgil's
Drives: 2010 2SS M6 Join Date: Feb 2014
PM matthew9440 and he can get one for you. May be some others that work at a dealer that can get one as well. Search for build sheet on here.
2010 2SS/RS M6 - CAI Intake - Borla Stinger - VTC - 3.91's
Eibach Sways - LG ZR28's - BMR Springs - 285/35 Squared |
