04-15-2021, 01:22 PM | #15 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
I had used Amsoil gear lube in everything I owned for decades. The Camaro rejected it by making all kinds of noise. GM lube cured all problems. Go figger. It’s a GM car. Take that for what it’s worth.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
04-15-2021, 01:32 PM | #16 |
Camaro #4
Drives: 2017-Hyper Blue Metallic-2LTmanual Join Date: Dec 2015
Amsoil is what I've used twice now in my trans and diff. The first time I changed it out at 50k from GM to Amsoil and Amsoil again now at 140k.
Don M
Supercharged LGX + 6 speed manual = FUN!! |
04-25-2021, 12:41 PM | #17 |
Drives: 2015 camaro ls Join Date: Apr 2021
fixed differential humming noise
I dumped out the Valvoline oil and replaced the differential oil with the factory recommended oil and additive. After driving around for 2 minutes, the differential box is quite as "a mouse". The total cost of oil and additive is $28 from ebay. I tried to save money by buying non-OEM stuff, but it ended up costing me more. Lesson learn... There are somethings that can't be had for cheap. Thanks all for the replies!
04-25-2021, 12:58 PM | #18 |
Amsoil Severe Gear 75w-90 in my diff. My car is so loud that I don't think I would even hear any diff noise, so that may be an issue lol.
I did NOT use any additional friction modifier with the Amsoil since everyone I read that used it on our diffs said it's not needed.
04-25-2021, 05:48 PM | #19 |
Drives: Two 1984 Z28 / 2014 2SS/RS AGM L99 Join Date: Feb 2021
I'm fixing to change mine as well with the oem recommended fluids . Question I have is , capacities chart says 1 quart . So is it one quart total , or 1 qt. fluid and 4 oz. additive which would make 36 oz. ? Thanks for the help .
04-25-2021, 08:29 PM | #20 | ||
Check out my jack stand on youtube here. It's the safest jack stand you can get. |
04-26-2021, 08:35 AM | #21 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
x2, just start with the additive and then add fluid until it comes out the fill hole. Or add half a bottle of fluid THEN throw the full additive bottle in and then finish topping off. Can never tell exactly how much it will take, but you want to make sure you get all of the additive in.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
Tags |
differential, humming noise |
