06-09-2014, 09:47 AM | #1 |
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
Flow-tie, now what to do with it?
So I made a flow-tie last night from my stock front bow. I really like how it's turned out so far, but I'm not quite sure what to do with it now.
I know I don't want it chrome, so that's the first question: how do you prep this for paint? Would a light sanding work or would I need to find some sort of stripping agent? The chrome plating seems fairly durable and I know it would take quite a bit to get it scuffed up to be able to take paint. Next, what color to I make it? -Textured matte black to blend into the grill for more of a ghost look? -Yellow to maintain the theme since everything else on the exterior is yellow/black -Red as a "shout-out" to the Bumblebee in Transformers 2? I'm leaning more towards the black or red simply because I know I won't be able to color match it very well and it would look bad if it doesn't match. And finally, how the **** do I attach it? I'm thinking of epoxying a couple long, thin bolts (one on each end), then drilling matching holes in the grill, and using a washer/nut to "clamp" them on from the inside of the grill. Here's a pic of the progress so far:
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build Last edited by Dexman1349; 06-12-2014 at 01:11 PM. |
06-09-2014, 05:52 PM | #2 |
Drives: '16 2SS Join Date: Apr 2011
Etching primer.
The usual way to mount is to get a Drake Bow-Tie Delete plate. Keep in mind that this started years ago as the SSX bowtie. |
06-09-2014, 06:02 PM | #3 |
SHKE BKE
Drives: 2013 Camaro Join Date: May 2014
How did you cut the stock one?
06-09-2014, 06:04 PM | #4 |
2010 2SS/RS M6
I used a Dremmel with a cutting wheel to cut most of it then used a small handsaw to get the corners. I then went around the inside with a good file to smooth it out. It took me close to 2 hours to get it all hollowed out and cleaned up.
Unfortunately, cutting off the back also completely removed all of the pegs/tabs that held the original in place...
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
06-09-2014, 06:08 PM | #5 | |
2010 2SS/RS M6
Here is a pic of what Bee looks like now (avatar is an old pic) http://www.camaro5.com/forums/showpo...33&postcount=1
06-13-2014, 10:31 AM | #6 |
ACE5 (Atlanta Group)
Drives: "Black Ice" Join Date: Sep 2010
The plastic chrome usually comes off by soaking the part in bleach. Yep, good ole Clorox. Let it sit overnight. May need a little bit of scotch-bright pad, but it will all come off.
Custom Two-Tone Paint, Whipple, Pedders, NightOwl RGB Halos & Other Lighting
[COTW 5/2/11] 2011 Two-Tone White/Black SS/RS Convertible See our Atlanta Social Group or home page: ACE5.org |
06-13-2014, 10:49 AM | #7 |
Nice tip!
06-14-2014, 09:15 PM | #8 |
The pride of the CN
Drives: '13 AGM 2SS/RS M6 & '70 Chevelle SS Join Date: May 2013
Send a message to Denis on here... he did one like this and found a good way to attach it.
"I've been working on the railroad, all mother f###ing day." ...and yeah, we hauled your Camaro.
Class 1 Freight Rail Conductor - Master Mason - NRA Life Member - Tennessee Squire - Firefighter I & II Certified My other ride has 4,400+hp and corners like it's on rails... because it is. |
06-16-2014, 08:00 AM | #9 | |
http://www.camaro5.com/forums/showthread.php?t=354037 hope that helps! |
06-16-2014, 09:59 AM | #10 |
2010 2SS/RS M6
Yeah, I pretty much did the exact same thing and have it up to the paint part right now. Problem I'm facing is that I don't have that grille anymore so I can't use the bowtie delete kit.
I'm sure I'll get something figured out... Thanks for the help!!
06-16-2014, 12:24 PM | #11 |
oooooooh i got ya. i just looked at your signature pic and saw the OE grill. hmmmmm.
i think someone did something with the Zl1 grill too. you need to cut the center out of the grill though. not sure if thats something you want to do. |
