Vararam
Old 12-08-2016, 05:53 PM   #1
enroberts
Drives: 2010 Inferno Orange 2SS Camaro M6
It's time for a more comfortable ride
Howdy. My Camaro has some significant suspension and driveline upgrades including:
  • 9" DSS rear, CF driveshaft, DSS axles
  • stainless trailing and toe arms with Delrin bushings
  • Eibach lowering springs
  • aluminum subframe connectors
Let me tell you, the power gets to the ground now, but man, the ride is terrible! That said, what do you folks recommend for shocks and springs to soften the ride a bit when on the road? Any other changes you all might recommend for a better ride? Christmas is coming and I need to put a list together LOL. Thanks!
LS3 | Magnacharger 2300 supercharger | ZL1 fuel pump | FAST 65lb injectors | 3.4" pulley | JRE belt tensioner | Elite RX clean/dirty side catch can system | CAI | Magnaflow Exhaust | Monster Clutch LT-1S twin disc | Tick remote clutch bleeder | DSS Carbon Fiber DS | DSS 9" rear with 3:70 Wavetrack gears | DSS 1400HP axles | Pegasus CNC stainless steel trailing/tow arms/solid subframe connectors | Hurst short throw | JBA mid pipes | Bosch wide-band O2 sensor | Innovate Motorsports LC02 wide band controller | Innovate Motorsports Air/Fuel/boost gauges | Baron Concepts center speaker gauge pod
enroberts is offline   Reply With Quote
Old 12-08-2016, 06:12 PM   #2
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Get rid of everything you put in.....srsly...every item you list connects your ass that much closer to the road...which IMHO is exactly what everybody is lookin for...so...could also by a 2nd car?
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
frankwjr is offline   Reply With Quote
Old 12-08-2016, 06:15 PM   #3
enroberts
I have 4 other vehicles and can take another one out for a better ride. I know what the purpose is for the pieces I installed, that's why I installed them. What I'm asking is, would shocks (since I'm still running stock shocks) and better springs help with ride comfort?
Old 12-08-2016, 06:26 PM   #4
frankwjr
frankwjr's Avatar
I guess if you could get the magnetic ones some how installed but the suspension is setup to work a certain way within predetermined parameters and if you go to far then basically it would become a turd....maybe get 18" rims with a taller tire side profile would soften it up? I want to get a setup like spinmonster over at corvette did...looks stock but is a killer street sleeper setup...just on the rears tho...
Old 12-08-2016, 06:33 PM   #5
LStick
Drives: 2021 Shadow Gray 1LS
My Camaro rides about as smooth as a third generation Vette.
I do have a second vehicle for days when my back can't take it.
LStick is offline   Reply With Quote
Old 12-15-2016, 03:02 AM   #6
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
replace the delrin with poly keep the sub frame bushings and get adjustable coil overs.
Old 01-03-2017, 08:00 PM   #7
camaro4mybday
"Camaro Joe"
camaro4mybday's Avatar
Drives: 2010 SILVER ICE 2LT/RS CAMARO
Send a message via AIM to camaro4mybday
air ride is the only thing that will make it comfortable
camaro4mybday is offline   Reply With Quote
Old 01-04-2017, 10:56 AM   #8
JSRidetech
Drives: Mustang/Camaro
We currently have both setups. Air is great for adjustability, but not necessary for ride comfort. When done right a coilover car can ride just as good as a air car. Let us know how we can help.
http://www.ridetech.com/store/muscle...ures_hash=V359
JSRidetech is offline   Reply With Quote
