08-05-2015, 06:05 PM | #15 | |
Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
As for the heat issues, I am assuming you are talking about the A8 issues in the C7 Corvette. I have been following that a bit (but am not expert), and there are many key differences for the C7 with regards to the transmission and heat. 1. The Corvette's transmission is not directly connected to the engine like the Camaro's will be (and most every car on the planet), it is connected to the differential with a shaft the connects the engine with the transmission. So it's just in front of the rear axle. 2. Folks seem to think the heat issue is caused by the exhaust running close to the transmission in the rear of the car. So there may not be an issue with externally added heat to begin with in the Camaro as it is a completely and more traditional setup. 3. The C7 has an optional transmission cooler that collects air from the vent over the rear wheel, using forced induction under driving, with an electric fan that comes on when temps are too high. The Camaro has a completely different setup with a heat exchanger in the engine bay at the bottom of the box formed by the three engine coolant radiators. So again, the cooling is a completely different set up on the Camaro as well. So to me, we really can't make any legitimate comparisons with regards to this issue on the C7. I am not saying any of this proves there WON'T be a heat issue. But it should be obvious, it would be foolish to make an assumption that there WILL be an issue. |
08-05-2015, 06:46 PM | #16 |
Drives: '14 V6 RS, DM Exhaust, Sunroof Join Date: May 2015
First off, kudos to whiteboyblues2001 for an amazingly detailed post! Can't imagine the amount of time you put into that!
Second, here are some links that can get you up to speed on a lot of the terminology thrown around this site: http://www.drivingfast.net http://www.howacarworks.com The first site goes through a lot of the racing terminology like "heel toeing" to perform rev matching. The second, despite the name suggesting that it's an idiot's guide to cars, is an amazingly detailed description of how all the different car technologies work. Right down to explanations of each and every planetary gear. Pretty good stuff for getting caught up. Hope this helps!
08-05-2015, 06:56 PM | #17 | |
Drives: camaros in his dreams Join Date: Jul 2015
Well,they just opened a great circuit track in dubai and one of the best formula 1 tracks(yas marina)is 80 miles away so im gonna track this thing every time im free of college.the last time I went to a track I made a total ass out of myself so lets hope I get better by time |
08-05-2015, 07:39 PM | #18 |
Drives: TBD Join Date: Aug 2013
For those who think they'll use manual mode most of the time with the 8 speed auto and so will have the control and connection without the hassle of having to clutch, a word of caution based on experiences others have had with 8 speed autos.
I've been following the 2 series and M2 forums at 2addicts for quite a while. There are several former manual owners there who went for the highly-rated ZF 8 speed auto on their 2 series cars and came to regret it. Not because the ZF has any operational weaknesses, but because an 8 speed transmission leads them to have to shift too frequently for the process to be enjoyable - they wind up just letting the car do it automatically and then miss the driver involvement they had with their manuals. Last edited by DevonK; 08-06-2015 at 10:03 AM. |
08-05-2015, 07:51 PM | #19 | |
08-05-2015, 07:57 PM | #20 | |
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
08-05-2015, 08:01 PM | #21 |
Drives: 67 goat, 69 goat ram air III Join Date: Mar 2009
The article here on the A8 overheating said the auto mode was faster on the track than the manual auto mode as the drivers shifted at the wrong times. That said a track manual maybe better in a pros hands but not in the less drivers????
As one that has had several AFM engine issues, if one is on the fence about which, I would say stick and no AFM. One thing about a stick in a high TQ car is you can Sunday drive when you want to. In town, 2 to 3rd or 4th and then 5th if necessary? Also less chance of a casual thief jacking it. |
08-05-2015, 08:49 PM | #22 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Also, here's a comparison of M7 vs A8 acceleration times on the Stingray: http://www.camaro6.com/forums/showpo...0&postcount=37 The auto holds a slight advantage from 0-30... but between 30-100 and 30-150mph, the manual is as quick or quicker. Based on one data point from each .. but at least both tests conducted by C&D. Also, on a road course, the Z06 M7 was faster than the A8 when tested back to back by Motortrend. The manual Z06 ran a 1:25.00 and the automatic a 1:25.76. http://www.motortrend.com/roadtests/...#ixzz3hzmMTT8O I currently have an M6 in my '00 Z28 and love it, but I'm on the fence between the choice now. When I bought mine, the auto option had half the gears it has now! |
08-06-2015, 09:26 AM | #23 |
Drives: 2012 Camaro 2SS Join Date: Feb 2012
Some folks need to understand the difference between consistency and being faster. Rarely is an automatic truly faster it's just that a manual requires a bit more finesse. In the proper hands the C7 manual is faster than the automatic. There is also a significant difference in trap speed also.
08-06-2015, 09:55 AM | #24 | |
08-06-2015, 11:26 AM | #25 | |
Sent from my SAMSUNG-SM-N900A using Tapatalk
08-06-2015, 12:19 PM | #26 |
Drives: 2015 1SS/RS Blue Velvet Metallic Join Date: May 2015
This is the only point I think is more of a case by case thing, Ive been looking at a lot of vehicles recently and its the exception still for the auto to get better mileage than a manual (at least according to manufacturer specs) Although in almost all cases its close enough not to matter anymore.
08-06-2015, 01:58 PM | #27 | |
08-10-2015, 09:27 AM | #28 | |
