10-31-2014, 08:04 PM | #1 |
Drives: 4 wheels Join Date: Mar 2014
Differences between the LFX engines
So what is being done with this engine to have these spreads in numbers?
http://en.wikipedia.org/wiki/GM_High_Feature_engine#LFX |
10-31-2014, 08:09 PM | #2 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
Well there can be a several things. Like the Camaro may have a freer flowing intake and exhaust. And they can use different tunes for different applications. Probably the mechanicals are the same in all the engines. If the engine itself was different more than likely it would have a different designation for each application. Like previous to the 2012 Camaros had the LLT.
The Bird is the word! |
10-31-2014, 10:18 PM | #3 |
Stop writing "vert", ffs!
Drives: 2011 2LT Convertible Join Date: Feb 2012
Another likely reason is that there are different intake manifolds on some of those vehicles.
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator |
11-01-2014, 08:12 AM | #4 |
Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Tuning. Or just rating, honestly. Notice how the ATS has 2hp less and 4ftlbs less at peak. You can't exactly accurately measure that.
It's not like... um... the LSA and LS9, for example, that have different superchargers and various parts. They're all mostly identical, minus the intake manifold and the exhaust depending on the application, but it's just rating. Oh, like the Corvette and Camaro LS3. Notice how the Corvette has like 10hp more on the same engine. Yeah.
K&N CAI, 1LE Strut Tower Brace, Elite Engineering Catch Can and Clean Side Separator, Apex Scoop w/ Washer Relocation Kit, CTS Front Calipers and Rotors, JacFab Ported Intake Manifold, JacFab Intake Manifold Spacer, 80mm Overkill Throttle Body, SS Brake Lines, Ideal Garage Master Cylinder, Monster Twin Disc Clutch, NPP Retrofit w/ Magnaflow Resonated X, ARH Catless Downpipes, JRE Built 3.45 Diff, 1LE Axles, 1LE Hubs, Overkill Tuned, BMR Anti Wheel-hop Kit Stage I, ACS TL1 Hood Insert, ZL1 Spoiler
