TireRack
Old 04-07-2015, 08:45 PM   #1
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
Maggy guys... can you verify something for me.
I have the SLP jackshaft style supercharger which is basically a Magnuson with a different styled housing. Anyways, I'm going to be changing from the stock 3.8 pulley to a 3.6. My question is this. Do I need to buy a new belt or will the one I'm using for the 3.8 work? I have been told from several people that I can use the same belt that I'm using with my 3.8, but it all comes down to adjusting the tensioner. Can someone confirm this who has made the same swap?
newagemuscle is offline   Reply With Quote
Old 04-07-2015, 08:52 PM   #2
Jason P
Jason P's Avatar
Drives: 2011 2ss
I'm betting if you are still 6 rib your old belt is stretched anyway. I would get 2. A new one the same size and one the next size down. Return the one you didn't use.
2011 2ss Ram twin plate ceramic clutch, Texas speed 418 LS3 235 /243 .621 / .624 cam, ported and polished heads with dual springs,magnum push rods, Hotchkis race pack, Stainless Power long tube headers with no cats, Magna Flo competition exhaust, lpe fuel pump, magnuson supercharger with overdrive and port matched blower plate, IW 8 rib pullies, AEM meth kit, id 850 injectors, 3 bar map, halltech cai, zl1 rear diff
Jason P is offline   Reply With Quote
Old 04-07-2015, 08:54 PM   #3
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
If I remember correctly (way back when) the belt is the same.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 04-07-2015, 09:13 PM   #4
11TexaSS
11TexaSS's Avatar
Drives: 2011RedJewel, FI
Same one will work
11TexaSS is offline   Reply With Quote
Old 04-08-2015, 07:38 AM   #5
teachmezuo
Drives: camaro
well,Same one will work,thanks
teachmezuo is offline   Reply With Quote
Old 04-08-2015, 09:42 AM   #6
BooSSted
BooSSted's Avatar
Drives: 2017 Z06 / 2012 CTS
.... Same belt size, throw your old belt in your trunk as a spare; adjust idler pulley.
SOLD - Maggie Powered 2011 2SS
Procharged Powered 2017 Z06
BooSSted is offline   Reply With Quote
