dave@hennessey
Old 05-09-2018, 08:23 AM   #29
hntrgthrs
hntrgthrs's Avatar
Drives: 2015 ZL1
Originally Posted by Avenging Orange View Post
I've ask before and I will again......why are you stuck on a specific number? HP numbers do not make the car. I can find 400hp cars blasting 500hp cars all day long. It's the right combination of hp, tq, drivtrain, suspension, etc. all working in harmony.
Well said. Back when I was having my old GTO and G8 worked on, I really couldn't have cared less about the actual dyno numbers. To the point where I even forgot to ask at times. Unless you are bench racing or trying to put something in your car forum signature, no one should really give a shit.
2015 ZL1 Coupe - Summit White | Stock (for now)
hntrgthrs is offline   Reply With Quote
Old 05-09-2018, 09:14 AM   #30
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
Originally Posted by hntrgthrs View Post
Which is why dyno numbers are a pretty meaningless tool.
Useful in bench racing, though.
SAE says I make 450 on a dyno jet and STD is 470 lol Dyno numbers are just that...... numbers. I use the dyno to tune and smooth out the curve and the send it at the track where real results are.
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 05-10-2018, 08:00 AM   #31
Dylan1214
Dylan1214's Avatar
Drives: 2014 Camaro SS L99
Originally Posted by InFiD3ViL View Post
Even with our drivetrain loss?
According to GPI yes, This is the email I sent and response I got from them,
( What do you think i'd be pushing with this setup on 93octane? Max Package (62CC,a 232/254 cam on a 106 IC VVT) Plus the atomic manifold,Long tubes, 25%udp, and intake/exhaust?
We made 520 wheel on a manual trans on 93 with this exact set up. It made 542 on E-85. Yours should be with in 2 or 3 % of that with an auto.)
Honestly i'm just happy hitting 500, anything more is just a huge bonus lol
MODS: GPI MAX Package ported and milled heads+(229/250,111 LSA),Johnson 2110 Lifters,BTR .660 Springs,CHE Trunnions,C5R chain,DSX Flex Fuel kit,LSA Injectors,ZL1 Fuel Pump,MAMO Ported MSD Intake manifold,BOWhite ported Throttle body,25% UDP,CAI Intake,Intake Scoop,Kooks 1 7/8 headers,Borla attak catback,Elite catch can,BMR Motor mounts,CircleD 5C 4000-4200 Torque converter,ADM trans cooler,Jannetty Trans dipstick,DSS Aluminum Driveshaft,3.91 Gears,Eaton TrueTrac,JRE Billet caps,BMR Trailing arms,BMR Toe rods,BMR rear sway bar,Pegasus Solid sub frame bushings,DSS 1,000HP Axles
Dylan1214 is offline   Reply With Quote
Old 05-10-2018, 12:00 PM   #32
Taylortoons
Taylortoons's Avatar
Drives: 2011 2SS/RS LS3
Yep, I said the same thing...for about 6 months. Really, 550 isn't a lot more than 425 in terms of seat of the pants. Jump that number up to more than 750 and it's a whole new experience...
GPI Built Procharger D-1/13 PSI/Race Intercooler/SS3 Cam Kit/Kooks LTH/X- pipe/FIC 1050/E85/3.91 gears/Centerforce Dual Disc clutch/Flowmaster Outlaw/775whp/680tqSOLD
Taylortoons is offline   Reply With Quote
Old 05-10-2018, 12:40 PM   #33
1911 1LE
Drives: 2015 SW 2SS 1LE
You're going to have to be a strong S.O.B to stay happy @ 500hp. I thought I would be @ 485, 605, 640 and now 760. Wrong!!!
Maggie 2650 @ 18psi/ 75mm 10 rib/ Dual alky nozzles/ Roto-fab/ ARH 2" Lt's/ GT-12 cam/ ZL1 3.23 Conv./MGW/RPS triple carbon clutch/RSG tranny upgrage/Pedders Ex. XA w/ remote cans and a lot of other crap 897/8??@tires
1911 1LE is offline   Reply With Quote
Old 05-11-2018, 01:21 PM   #34
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Yes, We have done it with a few setups on SBE LS3/L99 stuff. My current setup is over 560 rwhp with out ported LS3 heads, and doing it through a TH400.
Rhino79 is offline   Reply With Quote
Old 05-12-2018, 03:13 PM   #35
Powered1le
Powered1le's Avatar
Drives: 2014 2ss 1le
No you will need a blower turbo or spray
2014 camaro 2ss/rs 1le [muffler & resonator delete, x-pipe , roto fab cai, 305 35 r20 rear tire 285 35 r20 front goodyear f1 supercar,1 7/8" tsp long tube headers with high flow cats, tsp Prc heads, K1 rods, Wisco pistons, 522whp 495tq, dynojet, btr stage3 cam kit, arp head studs and arp bolts.
Powered1le is offline   Reply With Quote
Old 05-12-2018, 04:07 PM   #36
Dylan1214
Dylan1214's Avatar
Did you not read any posts? It's very possible
Old 05-13-2018, 06:27 PM   #37
Powered1le
Powered1le's Avatar
At what expense are you willing to take to get 500wrhp. Other than spraying it is a very good way to get 500wrhp without major problems.
Old 05-13-2018, 06:55 PM   #38
xc_SS/RS
Drives: 2010 Camaro SS/RS
Yes, a turbo, two turbos, supercharger, or NOS are good ways to get to 550whp. The only issues with that answer is the OP wanted to know if 550 whp is possible staying N/A, or all motor
Not many risks being taken to reach 550 whp all motor. It is very possible
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 05-14-2018, 04:04 PM   #39
Baddbird
Baddbird's Avatar
Drives: 2014 2SS
If that's the cam you plan on running I think your
gonna need to flycut the pistons.
Baddbird is offline   Reply With Quote
Old 05-14-2018, 04:11 PM   #40
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Lots of cam
Lots of cylinder head
Lots of compression
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Bo White is offline   Reply With Quote
Old 05-14-2018, 04:31 PM   #41
Dylan1214
Dylan1214's Avatar
Normally yes, But the Max package comes with modified LS7 heads for more PTV clearance/Cam
https://gwatneyperformance.com/produ...d-cam-package/
Old 05-14-2018, 04:44 PM   #42
Baddbird
Baddbird's Avatar
Drives: 2014 2SS
Yeah I know. I built my car with the L99 Max Package. I own the "previously bone stock 339hp" car that Ryan spoke of in the GPI max thread.
500, all motor, ls3
