11-19-2015, 11:10 AM | #1 |
Drives: Sonata Join Date: Sep 2012
2016 Camaro V6 in Snow
HI Guys,
I just need some suggestions to drive this car in snow. With so much technology and advancement I wonder if rear wheel drives are still not good on snow. Taking 2016 Camaro in perspective, weight distribution is 48% back and 50% front. Also car has snow mode(not sure what it does other than controlling the throttle response). This 2016 with a good set of winter tires can this be as good as a FWD if not AWD? Your experiences and thoughts please. Thanks in advance. What tires do we get from factory? Mustang with performance package gets summer tires, just wondering if Camaro's get summer tires too. Last edited by czaarsvk; 11-19-2015 at 11:21 AM. |
11-19-2015, 11:21 AM | #2 |
Drives: None Join Date: May 2012
Winters tires will good for handling and breaking. Acceleration might be the only aspect where rwd will hinder compared to awd. But it's certainly drivable in the snow with snow tires.
11-19-2015, 11:23 AM | #3 | |
Probably doesn't like you
Drives: 2022 WCT ZL1 M6 Join Date: Jun 2015
Will it be better than a FWD with snows? Maybe. Driver dependent, vehicle dependent. Will it be better than an AWD with snows? Probably not. Driver dependent, vehicle dependent. Common sense applies.
كافر ΜΟΛΩΝ ΛΑΒΕ железобетонное очко Quod gratis asseritur, gratis negatur. There is an unequal amount of good and bad in most things, the trick is to work out the ratio and act accordingly. |
11-19-2015, 11:46 AM | #4 |
Drives: 2011 Camaro SS Join Date: Apr 2013
Regardless of whether it comes with summer-only tires or even "all season" tires, dedicated winter tires help a lot when it comes to driving on packed snow because they have treads that are engineered specifically for that purpose. A RWD car with proper winter tires will typically perform better than an AWD car with summer times when it comes to maneuvering up a snowy incline. Keeping some sand or cat litter in your trunk is also a really good idea. If you sprinkle it on the areas directly in front and behind the rear tires, then gently rock the car in drive and reverse, you can make a much better contact area for getting out of a tough spot. AWD is totally useless if all 4 wheels are spinning and doing nothing.
Even if you live in an area where it rarely snows but still drops into freezing temps, winter tires are better. The rubber composition of summer-only tires isn't designed to operate in cold conditions, and it can lead to faster wear. Despite all the above advice, I personally never swap my tires throughout year even though the last few winters in NC have been colder then usual. This is mainly because my commute is only 10-15 minutes and I can work from home if conditions are particularly bad. It really boils down to the individual and your circumstances. If I had a family, for example, I'd honestly probably buy light-weight truck like the Colorado for winter months since I'd need to provide them reliable transport. |
11-19-2015, 12:01 PM | #5 |
Drives: 1969 Corvair, 2018 Camaro T4 RS Join Date: Mar 2009
Good ^ answers. The SS has summer onltywhile the LT, including RS LTs, has all seasons.
Laborsmith |
11-19-2015, 12:05 PM | #6 |
Drives: 2018 2SS Camaro Hot Wheels Edition Join Date: Sep 2015
This being my first Camaro, I've been told that with snow tires, preferably 18" that driving in the snow, you will be fine. Now, of course if there is a blizzard, play it safe and stay home. But other than that, your good to go.
Zack46
2018 Camaro 2SS Orange Crush Hot Wheels Limited Edition Power Sunroof, 8 Speed Auto/Remote Start, NPP Exhaust Production Sequence Number 98 NEOCC Camaro Club Member Former Ride: 2016 Camaro 2LT RS V6 Hyper Blue Metallic |
11-19-2015, 12:06 PM | #7 | |
Drives: BMW 335i BMW Z4 M Roadster Join Date: Nov 2015
A RWD car with winter tires will outperform a AWD car with all seasons in winter condtions. Here's what happens to summer tires in the snow: M3 on winter tires vs AWD suv on summer tires |
11-19-2015, 12:21 PM | #8 | |
I wouldn't go as far making such a blanket statement. My Infiniti M37x on Bridgestone A/S has proved that I don't really need winter tires, and it did it during the snowiest winter New England has seen in 20+ years (last year). The year before we had a G37xS, and it had snows, and it was completely amazing. We traded up to the M37x, and the old snows didn't fit. I decided to see how it would do, and it came through with flying colors. Top notch AWD systems still have huge advantages over RWD cars when it comes to traction. That difference is smaller with better tires, but not all A/S 'suck' in the snow. Some are quite capable. I'm sure each side can come up with situations where one would excel, but blanket statements like this are just wrong and can give the wrong impression to people who are seeking information.
11-19-2015, 01:21 PM | #9 |
Dodges all the cones
Drives: Soon Join Date: Sep 2015
Then when I put snows on my Subaru, it's a snowmobile. I've gone around those stereotypical AWD/4WD drivers that have zero clue about tires, and think that AWD/4WD is the cure all... no, it isn't. Tires for the conditions make all the difference. I should work for tire rack, but I don't want to move to Indiana. --kC |
11-19-2015, 01:35 PM | #10 | |
Zack46
11-19-2015, 02:08 PM | #11 | |
I'm sure your AWD Infinity did great in the snow and got you around just fine. But that doesn't change the fact that snows would have been better and safer and would have allowed higher cornering speeds and shorter stops. My S4 on all seasons handled the heavy snows and steep hills of Lake Tahoe just fine. But when I switched to snows it was in a completely different league. All of the accidents I've seen are not because people couldn't go, it was because people couldn't stop or turn. That's where snows will help and a Camaro with snows will be great fun in the snow and as long as you're not driving through deep drifts then you'll do just fine. Just don't leave the summers on like my brother did with his GT500 because then you'll even get stuck in your own driveway on basically flat ground. |
