Old 02-08-2015, 07:33 PM   #1
Test_Eng
Drives: 2013 1SS RS 1LE NPP ADM LSA CON
Another ADM, LS3 to LSA Build
Placed my order with ADM today. I can see some long nights ahead of me to get my car ready before the spring.
I still need to locate an intake, blower and base tune. If anyone has any good leads please PM me.
My order:
LSA Supercharger Dampner
NGK TR7
ADM FPCM
2.5" LSA 2 Piece Pulley
65lb Injectors
ADM LSA Install Kit W/O Supercharger
My current car setup:
1SS 1LE NPP
Kooks Headers w High Flow Cats
K&N CAI
Goal: 550 to 600 RWHP reliable car.
Think I can meet my goal without a CAM?
Lots more pics to come...
Test_Eng is offline   Reply With Quote
Old 02-08-2015, 09:09 PM   #2
Juice2SS
Drives: 2011 2SS
I just put down 551rwhp on the pump gas tune and 8 pounds of boost through an auto. I bet you do fine.
Juice2SS is offline   Reply With Quote
Old 02-08-2015, 10:00 PM   #3
smokum
smokum's Avatar
Drives: 2010 2ssrs
Awesome choice. You will be really pleased with the kit. Is there a reason for not doing a cam? An ls9 cam would help you hit your goal and run smooth yet. They are amazingly cheap. Adm uses them all the time in forced induction engines. The dampener is not a needed part. I would save the money and get an ls9 cam instead. With a stock cam and a 2.5 pulley you will make way too much boost. With the ls9 you will make less boost and more power and less heat. If you dont mind some cam thump go with a stage 3 cam. My car drives great and sounds awesome. I would call andy and talk to him on your goals. He is a great guy to talk to and has endless knowledge on what you want. He can give you comparisons of past builds. Hope this helps. Good luck on your build. Your heading in the right direction.
smokum is offline   Reply With Quote
Old 02-09-2015, 04:06 AM   #4
ddaman922
ddaman922's Avatar
Drives: 2014 Red Hot 1SS M6
Thinking of doing the same thing. I want to spend less than $5k if that's possible. You can get the blower and lid for $1k or less if you look on ebay and this forum.
2014 Red Hot 1SS M6 aka Bernadette
ADM LSA Conversion, ADM FPCM, 2.75 pulley, ZL1 fuel pump, FAST 89lb injectors, NGK TR7IX, Roto-fab intake, Stainless Power 1 7/8" long tubes w/o cats, NPP, Elite catch can, LG G5 Coilovers, Hurst shifter, GM strut tower brace, 1LE steering wheel, MRR 228 wheels, Nitto Invo 275/315.
Tuned by Lashway Motorsports 575rwhp 528rwtq.
ddaman922 is offline   Reply With Quote
Old 02-09-2015, 05:57 AM   #5
smokum
smokum's Avatar
Drives: 2010 2ssrs
Lid comes in the install kit from adm. All you need is the blower itself.
Old 02-09-2015, 07:27 AM   #6
Rumbumbees$ponsor
Rumbumbees$ponsor's Avatar
Drives: Autobot
What PSI and HP do these kits max out at? Pump gas.. Not meth or E85 tunes?
Rumbumbees$ponsor is offline   Reply With Quote
Old 02-09-2015, 09:34 AM   #7
ddaman922
ddaman922's Avatar
Hmmm. Good to know!
Old 02-09-2015, 11:36 AM   #8
ADM PERFORMANCE
Drives: Anything I want
Unfortunately your factory engine is on the Edge at 650rwhp(almost 800flywheel)
Old say - "not if but when"
ADM PERFORMANCE is offline   Reply With Quote
Old 02-09-2015, 12:49 PM   #9
camarosspower
camarosspower's Avatar
Drives: 2010 camaro ss
Will the nightfury cam work with this LSA Sc ?
camarosspower is offline   Reply With Quote
Old 02-09-2015, 01:12 PM   #10
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
You'll want a blower friendly cam. My VVT SS1 is better suited for NA. I'll be replacing mine with a BTR spec stage 1 Supercharger cam...
Andy knows what works with this kit...
-Don
hammdo is offline   Reply With Quote
Old 02-09-2015, 01:14 PM   #11
hammdo
hammdo's Avatar
My order:
NGK TR7
ADM FPCM
65lb Injectors
1SS 1LE NPP
K&N CAI
Attachment 692964
BTW, HFC's will need to go. Just a heads up
-Don
Old 02-09-2015, 02:09 PM   #12
camarosspower
I thought the NF was blower friendly
Old 02-09-2015, 04:19 PM   #13
Jared91
Jared91's Avatar
Drives: 2011 Camaro SS/M6
I'm running the Night Fury Cam with a PD blower and it works great. My tuner was pretty impressed considering it is a true NA cam. Is there more efficient options, yes but if it's in there already I wouldn't go out of my way to replace.
2011 Ls3. Slp TSV2300. 8PSI. 3.4 Pulley. Livernois Twin Fuel Pump. Id850 Injectors. Slp 1 3/4 headers. CAI Cold Air Intake. 3inch exhaust. V-Maxx portted throttle body. Night Fury cam. Lpe 391 gears. Fj performence tune. 643rwhp 574rwtq
Jared91 is offline   Reply With Quote
Old 02-09-2015, 04:32 PM   #14
camarosspower
That's what I wanted to hear
