Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 02-04-2017, 08:42 AM   #1
Aprojectile
Aprojectile's Avatar
Drives: 2012 Camaro LS
Best hood for downforce?
Hello, I'm wanting to know which hood offers better downforce and heat extration, the ZL1 hood or the 14+ SS/Z28 hood? I plan to track my car eventually and with how I drive it through the windy roads where I live, I would like the get more downforce than the stock non vented hood. Plus help pull out some heat within my engine bay too.
Aprojectile is offline   Reply With Quote
Old 02-04-2017, 03:19 PM   #2
Lonewolf583
Apex Predator
Lonewolf583's Avatar
Drives: 2010 2SS/RS M6 Rally Yellow
I'm not certain if anyone's done any kind of definitive testing to say which is "better". But I can say going in that direction can't hurt anything. I know of members who have installed the SS/Z28 hood extractor on the non-vented hood and were pleased with the results. I'd probably do that AND invest in a good splitter.
The OEM designs are definitely not the most optimal outright but they had aesthetics, cost, packaging, water intrusion, etc. constraints to consider for a street car.
2010 Camaro 2SS/RS - LS3/TR6060, Paid Off \o/
Beating physics into submission since 1991.
Lonewolf583 is offline   Reply With Quote
Old 02-04-2017, 03:21 PM   #3
Aprojectile
I don't like the way it looks just cutting a stock hood and putting the vent it, those body lines really help it blend it. And I've already invest my money into everything else other than the hood.
Old 02-04-2017, 04:04 PM   #4
Lonewolf583
Apex Predator
Hard to tell that from your post.
Each his own. I think this turned out just fine.
http://www.camaro5.com/forums/showthread.php?t=346744
Old 02-18-2017, 10:56 PM   #5
Dropspeed
2013 Camaro SS1LECTSVZ28
Dropspeed's Avatar
Drives: 2013 AGM 1SS/1LE
Swapping hoods will not create down force....It will reduce the inherent lift associated with the non-vented 2010-2013 cars without vented hoods at triple digits speeds
If you install a ZL1 hood upgrade the front and grille as well. The SS grille creates a buffering/turbulence when used with the ZL1 hood. That is why GM uses a unique grille on the ZL1.
Dropspeed is offline   Reply With Quote
