Roto-Fab
Old 05-29-2020, 10:28 PM   #1
Lb35
Drives: Honda Civic
Civic si or camaro
Deciding whether to get a 9th gen civic si or a 5th gen camaro. I want to learn more about both cars. I’m on a 10 k budget but want something fast, reliable, and fun. Any tips on what I should do?
Lb35 is offline   Reply With Quote
Old 05-29-2020, 10:32 PM   #2
Greenhornet2
Greenhornet2's Avatar
Drives: 2011 Camaro 2SS LS3 Whipple
$10k isn't gonna buy you a nice SS you're looking at a V6 for that. In that case i might consider the civic but the camaro is a much better looking car as pretty much anyone on this forum will tell you since we call own camaros lol. You could get a high mileage SS or one beat up a bit for 10k.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
Greenhornet2 is offline   Reply With Quote
Old 05-29-2020, 10:35 PM   #3
terry_b
terry_b's Avatar
Drives: 2014 2SS/RS 1LE
Send a message via MSN to terry_b
Camaro vs civic is so apples to oranges...
For 10k I'm not sure what kind of Camaro you're looking at, but that V8 is so satisfying.
But, if you care about full economy, then maybe not.
What are you looking for exactly? Just a fun car or a daily driver?
Sent from my Pixel 4 XL using Tapatalk
terry_b is offline   Reply With Quote
Old 05-29-2020, 10:41 PM   #4
gunchamp
gunchamp's Avatar
Drives: 15 Camaro SS
Youre gonna be 15k-20k for a 5th gen ss. As was already said, you would be looking at a v6. I would still go camaro, 300ish hp on the v6 and the best looking camaro body that has been made to date imo
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
gunchamp is offline   Reply With Quote
Old 05-29-2020, 10:59 PM   #5
Vegas Bound
Drives: 2013 Sparkly Red One
If you have to ask the question, buy the fart can car.
Vegas Bound is offline   Reply With Quote
Old 05-29-2020, 11:07 PM   #6
drew peacock
Drives: 2012 2SS INFERNO ORANGE
civic lol.
as a daily driver maybe.
listen to ole scotty kilmer and buy a celica
drew peacock is offline   Reply With Quote
Old 05-30-2020, 12:17 AM   #7
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
10k don't get even get you a nice SI
lemontwist is offline   Reply With Quote
Old 05-30-2020, 06:53 AM   #8
MrChrisLS3
Drives: 2018 1SS M6
Cheap
Fast
Reliable
Pick any two
MrChrisLS3 is offline   Reply With Quote
Old 05-30-2020, 07:32 AM   #9
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #831
Well this is an interesting first post. Welcome to the forums. Asking on a Camaro forum, you're likely to get everyone saying Camaro. Now with some of the comments so far, they're right. You're not likely to get into a "nice" SS for $10k, but a good V6 is definitely not out of the question.
The question does come down to application. You mentioned "fast, fun, and reliable". The V6 Camaro is reasonably fast, definitely fun, and overall reliable. There have been some people who have experienced issues with timing chains on early 5th gen V6 cars especially, but not all have and those that had it repaired more often than not never had to worry about it again.
If you're looking to modify for performance I would imagine the Civic has a much better aftermarket scene as the V6 Camaro is somewhat limited since most people who wanted to modify for performance went with a V8. Cosmetics are available all day long on a 5th gen as many parts are interchangeable between V6 and V8.
I have very limited knowledge about the Civic community as the last one I drove was a 90's hatchback 5 speed with 5 people in it and zero oil apparently (dumb chick didn't know you were supposed to do oil changes) and my personal preference is to buy from American manufacturers. Do your research and think about if you want front wheel drive or rear wheel as this can make a big difference in your decision, and pull the trigger on the car you want more.
'10 Camaro 2SS/RS | Aqua Blue #831 of 3,903 | Silver Stripes
Check out my build thread
Old 05-30-2020, 07:48 AM   #10
BehindBlueI's
Drives: 2011 Camaro SS
Save more money or set your sights lower.
BehindBlueI's is offline   Reply With Quote
Old 05-30-2020, 08:48 AM   #11
mikeman
Drives: 2015 Camaro
Since you already drive a Civic, I'd get the si.
mikeman is offline   Reply With Quote
Old 05-30-2020, 11:17 AM   #12
Lb35
Drives: Honda Civic
I was thinking v6 Camaro but not really modifying it as much engine wise compared to the civic si
Old 05-30-2020, 11:19 AM   #13
Lb35
Drives: Honda Civic
I was thinking more v6 camaro. I’m looking for both a fun car and a daily driver.
Old 05-30-2020, 11:24 AM   #14
Lb35
Drives: Honda Civic
Originally Posted by MrChrisLS3 View Post
Cheap
Fast
Reliable
Pick any two
Fast and reliable
camaro, civicsi
