Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing
Old 02-05-2014, 07:54 PM   #1
jake2212
jake2212's Avatar
Drives: none (yet)
Switching to a better oil, suggestions?
Hey all I'm thinking of switching from the Mobil 1 I have been getting at the dealership to something else. I'm leaning towards Royal Purple. Anybody have any suggestions?
jake2212 is offline   Reply With Quote
Old 02-05-2014, 08:00 PM   #2
Rob3D
Rob3D's Avatar
Drives: Car
Royal Purple is the best.
Rob3D is offline   Reply With Quote
Old 02-05-2014, 08:46 PM   #3
jake2212
jake2212's Avatar
Drives: none (yet)
Which kind?
Old 02-06-2014, 02:34 AM   #4
Rob3D
Rob3D's Avatar
Drives: Car
Originally Posted by jake2212 View Post
Which kind?
Dunno what you mean. Regular API, recommended viscosity.
Old 02-06-2014, 05:12 AM   #5
Cat988h
Cat988h's Avatar
Drives: Rally yellow 2011 Camaro 1SSRS
Amsoil Z-rod has a high zinc concentration and helps fight wear. I changed over when I installed my cam shaft.
ATI Super Damper, Katech C5R Chain, Jannetty 470 Comp Cam, Comp Valve Springs, Mellings Oil Pump, Manley Push Rods, Comp Tringion Upgrade, Cold Air Inductions Intake, 1-7/8 American Racing Headers w Cats, MBRP 3 Inch Exhaust, RX Catch Can, Eaton Tru Trac, 3.91 OEM, DSS Drive And Half Shafts, LPW Diff Cover,3 Inch Noweeds, Amsoil Z-Rod, Tuned by Jannetty Racing
Cat988h is offline   Reply With Quote
Old 02-06-2014, 05:57 AM   #6
Spartan01
Spartan01's Avatar
Drives: Evil Eva, 2010 2SS LS3
Amsoil Signature Series.
You may also want to swap out your other fluids as well, and Sea Foam your engine, then add a catch can.
"You simply cannot trust quotes found on the internet." -Abraham Lincoln
Spartan01 is offline   Reply With Quote
Old 02-06-2014, 08:42 AM   #7
Rob3D
Rob3D's Avatar
Drives: Car
That's great stuff too! Can't go wrong with that. Mobile 1 is great also... It's all a matter of your choice.
Old 02-06-2014, 09:08 AM   #8
CTS
Drives: 2021 Sierra Denali 6.2L/10sp CC 4WD
AMSOIL Z-Rod is not for newer engines, its API SL for 2004 and older automotive engines.
The current API Service Classification is SN
Signature Series ASL 5W-30 or AZO 0W-30 are the top of the line oils for a 2010.
Mike
Synthoil Supply
  • 2021 GMC Sierra Denali CC Ultimate 6.2L
CTS is offline   Reply With Quote
Old 02-06-2014, 10:25 AM   #9
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Z-rod is hard on cats due to the gobs of ZDDP. Amsoil Signature series or Pennsoil Ultra are great upgrades
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 02-06-2014, 10:30 AM   #10
Avenging Orange
Avenging Orange's Avatar
Drives: 2010 Inferno Orange 2SS/RS
There are so many oils better than mobil 1. Read some oil posts....or check out bob the oil guy.
2010 Inferno Orange 2SS/RS M6 Black Leather, Sun Roof, OBX Headers, Borla touring axle back, Cold Air Inductions CAI , non synthetic fluids, BMR total bushing upgrade/1" lowering springs, DSE 32mm rear sway bar. GM fe4 shocks/struts/LCA's, AAM 3.91 diff, Vertini RFS1.8 20x9 +30. Conti ExtremeContact Sport 275/35/20. sjm autoprod ABL dash kit. Mike Norris tuned 413/419.
Avenging Orange: 43 years of not buying into the Hype........and damn proud of it!!
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
KICKING CANCERS ASS SINCE 2015!!
Avenging Orange is offline   Reply With Quote
Old 02-06-2014, 10:31 AM   #11
DKT
DKT's Avatar
Drives: 2013 Camaro 1LE
I use Royal Purple HPS.
DKT is offline   Reply With Quote
Old 02-06-2014, 10:32 AM   #12
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Driven/ Joe Gibbs LS30
Let me know if you have any questions.
Best regards,
Tyler
888-308-6007
JDP Sales is offline   Reply With Quote
Old 02-06-2014, 08:26 PM   #13
Blk_SS
Drives: black on black 2SS/RS
What other high zinc oil can you get off the shelf???
Blk_SS is offline   Reply With Quote
Old 02-06-2014, 09:58 PM   #14
MaxKamai
Mad Ninja Skills
MaxKamai's Avatar
Drives: 2011 Camaro SS/RS M6
Best regards,
Tyler
888-308-6007
+1
2011 Camaro SS/RS M6 - 633whp/679tq Gave to the wife
Custom stainless 2" primary headers / Custom stainless 3" header back exhaust / Hurst short shifter / ZEX nitrous kit / Vararam intake / Spohn chrome moly trailing arms / Sin City Performance Tune / SCP custom ground cam / SCP ported & polished heads
New Car 2007 Corvette Z06 - Headers / Vararam / Magnaflow Catback / SCP Tune / Nitrous / BTR Stg IV Cam and Springs
MaxKamai is offline   Reply With Quote
