05-21-2017, 07:58 AM | #29 | |
Drives: 2016 Z06 coupe Join Date: Dec 2016
05-21-2017, 08:41 AM | #30 | |
Drives: 2017 SS A8 Hyper Blue/White Stripes Join Date: Jun 2010
The Mild2Wild just goes inline with the fuse that operates the NPP valves (interrupts the circuit with a fuse adapter, same as pulling the fuse) Your just able to control it remotely. I put one in for a buddy on his C6 Corvette. There is really no permit modification to the wiring in the car, it attaches in the fuse block. I would think it would work with any GM NPP system.
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD Last edited by Memphis SS; 05-21-2017 at 08:54 AM. |
05-21-2017, 08:58 AM | #31 |
Must be some differences as some say work on C6 but not C7 for example.
05-21-2017, 08:58 AM | #32 |
Drives: 2SS convertible, black,black Join Date: Apr 2016
It is the same unit as the Corvette.. Unfortunately they haven't changed the instructions yet.. Just get to them directly ( leea custom ) and order for the Camaro.. It will say Corvette...
IT IS GREAT..... Simple install and inexpensive. Install one and you will smile as you go down the road and press the remote.. Again, I use the garage door buttons instead of the remote.
A little known fact. Women with extra pounds, tend to live longer than men who mention it.
05-21-2017, 04:15 PM | #33 |
Drives: 2017 50th Anniversary Join Date: Dec 2015
For me it was a deal breaker. Of all of the options available the NPP was number 1.
05-21-2017, 04:25 PM | #34 |
Only problem on the nap is that when you first start it in tour mode it's still wide open. Used to on my Vette but one of the updates cured that problem. Only time on startup should they be open is sport and track. I'm sure my neighbors hate it at 5:30am.
05-21-2017, 04:49 PM | #35 | |
You can only YOLO once.
Drives: '16 2SS & '15 Subaru Forester Join Date: Jan 2016
If you have it, you have a whole world of possibilities for exhausts between ones that retain the NPP abilities to go quiet when you need it to all the way to ones that eliminate the NPP but still give you the quad exhaust pipes and nicer body trim. To me, even now that I am going to a Borla S-Type with NPP compatibility, I still feel that the initial cost to get the factory NPP was worth it. The only way that I would forego NPP in these 6th gens is if I was going full-race-car.
2016 Camaro 2ss
-Summit White / Ceramic White -8A, NPP, MRC, Ceramic White package plus knee pads, black bowties. -1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns. -1st Car to have the 6LEDesigns Blade Spoiler. -Borla S-Type w/ custom H-Pipe -Procharger P-1X Stage 2 |
05-21-2017, 05:56 PM | #36 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
I have full ARH exhaust from the motor to the muffler. I kept my NPP I like it that much. The Forza mild to wild unit works awesome on my car. I have the car set to stealth on button A and full time 100% open (same as a fuse pull) on button B. To start the car in stealth mode in the early AM hold the start button for about 5 seconds WITHOUT your foot on the brake it puts the car in accessory mode. Navigate to engine management settings and put the car in stealth mode you will hear the valves clank shut. Start the car and your neighbors like you again. The car absolutely closes the valves even in track mode on the highway or light throttle. With my 1 7/8 longtubes, AFM valves removed and hi flow cats there is nowhere near the crackling the stock exhaust had on Decel funny but it took me a few days to notice it was missing. Car sounds wicked on the throttle and is so tame with the push of a button. ZERO drone at all none.
2016 Hyper Blue 2SS A8,NPP,Moonroof
Pray ported factory intake manifold Ported TB Rotofab ARH 1 7/8 longtubes hi flow cats AFM deleted E85 11.0@124.9 11.65@118.8 pump gas,stock tune/exhaust New combo: Pray Performance Heads/cam MSD intake manifold and Circle D 3C 554/491 on E85 all work & tuning done by Pray |
05-22-2017, 01:47 PM | #37 |
YES... Corvette C6 unit will NOT work on 2016/2017 Camero.. The Covette C7 unit IS the correct unit... Again; check with supplier.. Love it
05-23-2017, 05:46 AM | #38 |
#TeamBeckyD
Drives: 2017 HBM 2SS Convertible A8 Join Date: Aug 2008
With the NPP I save myself from purchasing an aftermarket exhaust I actually like the sound.
#TeamBeckyD
**FIFTY HBM 2SS VERT** |
05-23-2017, 06:07 AM | #39 |
Drives: 16 Red Hot 2SS Join Date: Oct 2016
Another benefit of the NPP is the gloss black rear bumper diffuser vs the matte black plastic.
'16 Red Hot 2SS A8 sunroof
05-24-2017, 05:06 PM | #40 |
Drives: 2017 50th SS Convertible Join Date: Nov 2016
Sound considerations aside, I think the dual exhaust just looks better.
05-24-2017, 05:32 PM | #41 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Absolutely worth it. Don't buy an SS without it!
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
05-24-2017, 06:00 PM | #42 |
Drives: 2016 1SS Join Date: Jan 2016
Love my NPP!
1SS, Black, Black Wheels, A8, MRC, NPP
Thread Tools | |
