Vararam
Old 07-04-2014, 05:16 PM   #1
Knockoutpie
Knockoutpie's Avatar
Drives: 2014 2SS RS Coupe
Led Strips not sticking
Hey guys having a few issues not sure what to do. Bought some LED strips, and the 3m on the backside doesn't stick to the glove box under side, passenger underside of steering wheel or metal shelf in the trunk. Are you guys using something else to make these stick?
Knockoutpie is offline   Reply With Quote
Old 07-04-2014, 05:50 PM   #2
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
Peel the tape off that came with the strips. Go to any auto parts store and get some 3m emblem tape. That stuff will hold better. and prep the surface real well
GVA 45TH 2SS is offline   Reply With Quote
Old 07-04-2014, 06:10 PM   #3
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
And don't tape it to the plastic under the glove box, move it forward more (towards the front of the car)
I am not childish, you're just being a poopy head!
FL1CK is offline   Reply With Quote
Old 07-04-2014, 06:29 PM   #4
sycraft
COTW 5/06/2013
sycraft's Avatar
Drives: 2017 Corvette Grand Sport-Ho-Vette
zip ties...
2017 Grand Sport, Borla X Pipe.....Enough Said
sycraft is offline   Reply With Quote
Old 07-04-2014, 07:17 PM   #5
Kendell347
Doc
Kendell347's Avatar
Drives: BLACKOUT & Fifty
Use rubbing alcohol to clean the area before applying the new 3m tape. A lot of people glob on armor all and nothing can stick to the surface
Sent from BLACKOUT using Tapatalk
1100-7/20/2009 * 6000-2/4/10 Proud Owner of Autographed Litho # 1282010 Camaro 2 SS/RS - BLACKOUT & 2017 Camaro 2 SS - 50th Anniversary #894 WWW. NY5THGEN.COM
Kendell347 is offline   Reply With Quote
Old 07-05-2014, 06:04 PM   #6
sjmautoprod
sjmautoprod's Avatar
Drives: '16 2SS
Adhesive quality on strips varies greatly. If they don't stick, and you prepped correctly, replace the adhesive.
sjmautoprod is offline   Reply With Quote
Old 07-05-2014, 06:11 PM   #7
Knockoutpie
I ordered some new strips, ordered some 3m acrylic tape, and will remove the current adhesive and use alcohol to clean before applying! Thanks guys.
Old 07-05-2014, 06:14 PM   #8
Knockoutpie
And if anyone can please take some pictures of where they have their leds mounted on the passenger side. It would greatly be appreciated if you showed me!!
Old 07-05-2014, 06:43 PM   #9
GVA 45TH 2SS
KNGTFALL
Mine are zip tied for the foot wells.
But my under carriage are mounted the way I stated above.
Like SJM stated The adhesive quality is different between manufacturers. I don't even risk it anymore I peel it off an use the emblem/molding tape.
http://www.autozone.com/autozone/acc...ier=517047_0_0_
Old 07-06-2014, 10:59 AM   #10
gs31322
Drives: 2014 Camaro RS, Black
I'm a noob at this and I'm wanting to mount some LED in my CAI intake. How would I tap into the wiring? I dont want to tap something wrong and set my car on fire.
gs31322 is offline   Reply With Quote
Old 07-06-2014, 11:05 AM   #11
sjmautoprod
Drives: '16 2SS
We have plug-n-play kits for that if you don't want to tap anything. See some examples here...
http://www.camaro5.com/forums/showthread.php?t=249558
