Roto-Fab
Old 11-21-2012, 09:40 PM   #1
yellowrs
Drives: 2010 SS 426 V8 M/T
My Camaro SS all the sudden feels slower???
Not sure what it is going on but all the sudden my V8 SS2 feels aweful slow?
No mechanical issues what so ever.
Are I am getting used to the speed and power of the car or are I am crazy??
yellowrs is offline   Reply With Quote
Old 11-21-2012, 09:43 PM   #2
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Maybe it could be that fuel issue, trying pulling the 5 and 20 fuze overnight, might help. Your car could simply of knocked down a fuel map.
Old 11-21-2012, 09:45 PM   #3
con10der
Con10der
con10der's Avatar
Drives: 2010 2SS/RS M6 IOM Rally Stripes
Time for mods!
2010 2SS/RS M6 IOM w/Rally Stripes. BLK CAI w/ADM,WW Relo,2" Kooks,3" Cats-Mids,Vmax Ported TB,Muff Del,Janetty SCT Tuned,Drill/Slot BLK Hawk rotors,Red Grani Brake Lines,Motul 600,IDEAL Master w/res,Moroso CC,Accel Silver Tips w/TVolt 10.4mm,MGW shift w/Retro hand/ball,ABL Kit,Billet/IOM pedals, ZL1 split,Lloyds SS mats,PC Droid4/MAXX docking,HW Solo2.
Pend Install: Launch/Shift Light,BMR Susp/1" Drop/Sways/Track Pack,GM 3.9. Future: Janetty Pumpkin w/PosiTrac,1400HP axl,CF DS,Tick Stage 2 Trans,3 Disc Clutch,4"quad tip,center exit AB w/diff...
con10der is offline   Reply With Quote
Old 11-21-2012, 09:46 PM   #4
upflying
upflying's Avatar
Drives: '86 Monte Carlo SS
Could be your power addiction.
Takes more to feed it.
upflying is offline   Reply With Quote
Old 11-21-2012, 09:51 PM   #5
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
Originally Posted by Comrando View Post
What are the temps in AZ?
A 2010 maybe a fuel filter. How many miles?
Shouldn't be as it self cleans and isn't replaceable. It is part of the fuel pump in the tank. Entire pump has to be swapped out.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 11-21-2012, 09:52 PM   #6
Obzen
Pull up Cougar!
Obzen's Avatar
Drives: 2016 2SS
It's probably just you. Sometimes mine feels slow sometimes fast. It all depends how the butt dyno is working.
Obzen is offline   Reply With Quote
Old 11-21-2012, 09:57 PM   #7
angie7
Smoked by a GIRL
angie7's Avatar
Drives: 2014 2SS/RS
Id do a fuse pull. Ive done it twice on mine when it felt sluggish. Worked both times. Like kjkjr27 said, pull fuse 5 & 20 overnite. If by chance its had anything less then 93 octane in it, run the gas down to E, then pull the fuses. If the gas hasnt changed, just do the pull and dont worry about running the gas down.
2014 2SS/RS Summit White w/ IOM interior "Powder 2.0"
angie7 is offline   Reply With Quote
Old 11-21-2012, 10:14 PM   #8
yellowrs
Interesting.
The temperatures are perfect right not, lower 80's during the day and upper 50's at night.
I will give the fuse pull a shot.
Car only has 9300 miles on it.
Been using 91 octane, that's all we have in AZ!
Old 11-21-2012, 10:18 PM   #9
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Interesting.
Run it down to an 1/8th tank. Fill up with a top tier fuel like Shell then do the fuse pull and see what happens.
Old 11-21-2012, 10:24 PM   #10
yellowrs
Just to clarify we talking about the fuse box inside the vehicle?
I have only been using Chevron since I owned the car.
Shell also only has 91 octane!
I hate to contaminate my fuel.
Old 11-21-2012, 10:25 PM   #11
yellowrs
Seems hard for me to believe.
I just does not feel the same for the last few days :(
Old 11-21-2012, 10:26 PM   #12
oldfriend
Drives: Fiat 500 E
Wrong on both , what you are feeling is a traditional way to find and justify a reason to move up the food chain ,[ AKA ] ZL1 .
Yep , that's what it is , and no , there is no known cure .
Good luck .
oldfriend is offline   Reply With Quote
Old 11-21-2012, 10:28 PM   #13
STINGS
Live for On Ramps!
STINGS's Avatar
Drives: 2010 Camaro/2LT/RS/T.F./6M "naomi"
Fuse box under the hood.
STINGS is offline   Reply With Quote
Old 11-21-2012, 10:31 PM   #14
yellowrs
Good luck .
This better not be the problem
