Old 04-05-2011, 07:22 PM   #1
Huck1974
Drives: 2011 2SS
This is driving me crazy
Reduced engine power....bla bla bla. Thought it was a plug wire issue and it still may be. After pulling over, I can try to crank it over and get nothing for a few minutes. Not even a click. The car is just pissed off for a bit. After that, it fires right up and everything is wonderful.
If I just rape the car, by the top of third gear I get the message on the display. It is like some kind of spark issue because of intense heat that is pissing off the computer or something.
Some of you guys are running a more extreme setup than me. I am hoping someone has seen this before.
Thanks
Huck1974 is offline   Reply With Quote
Old 04-05-2011, 07:56 PM   #2
Slowhawk
Drives: 1999 Trans Am
Don't know what your setup is but I'm guessing blower. Probly just the tune which points at the MAF high frequency or MAP/MAF sencing code.
Slowhawk is offline   Reply With Quote
Old 04-05-2011, 08:08 PM   #3
Huck1974
Drives: 2011 2SS
Twin turbo. I'll check into it. Thanks for the response.
Old 04-05-2011, 08:11 PM   #4
Graham Behan
Drives: Various
As Slowhawk said,
Really need to know the details of your set up, could be a MAF/MAP rationality check (tune related) or a component problem.
Graham
Graham Behan is offline   Reply With Quote
Old 04-05-2011, 08:25 PM   #5
Huck1974
Drives: 2011 2SS
Yes, looking at things, I'm maxing out the Maf. Going to tune again this weekend. Thanks again for getting my brain heading in the right direction. When talking to my buddy, he built the car for the guy I was playing with on the way home today. It was an 800 plus hp 572 BB build in a tubbed 69 Camaro. I had 6 to 8 lenghts on him when it shut down. lol
Old 04-05-2011, 09:07 PM   #6
Graham Behan
Drives: Various
Stock cal is at around 14500Hz = around 1000 g/s, unless the MAF is in a small tube, or has poor air presentation, it should not be maxed on frequency.
Graham.
Old 04-05-2011, 09:28 PM   #7
S-eatin-grin
S-eatin-grin's Avatar
Drives: 2013 2SS/RS AGM
Thanks
I'm not claiming to know what's wrong but I had a 1989 Z-24 that was doing the exact same thing and the ECM had to be replaced...thankfully it was still under warranty. It cost about $550 back then..who knows how much one would be today.
S-eatin-grin is offline   Reply With Quote
Old 04-05-2011, 09:39 PM   #8
Huck1974
Drives: 2011 2SS
Graham.
It has been relocated. It is a very large tube. I actually had this happen on the dyno while recording. I'm going to go a different direction on the tune this weekend. If it does not work, I'll be back to asking you guys for help again and I will be able to provide more info. I have pretty much eliminated the plug wire scenario.
Thank you guys again.
Old 04-05-2011, 10:53 PM   #9
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
Was the wiring harness and all down near the turbos heat shielded?there is a pretty substantial harness running near them on the passenger side... Could be something in there...
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
Old 04-08-2011, 06:29 PM   #10
4xchamp
MURC 666
4xchamp's Avatar
Drives: 69 Pace Car 68 Camaro Restomod 81 Z
Huck , I had a maf problem causing my car to stumble slightly when leaving a stoplight and surge at light throttle cruise . ( cammed N/A though )
I'm confident you'll nail it soon whatever it is .
Guys hoarding their Camaros are depriving some youngster the opportunity to restore it 25 years from now .
Drive it like you stole it , let the next guy baby it !
4xchamp is offline   Reply With Quote
Old 04-08-2011, 08:42 PM   #11
Huck1974
Drives: 2011 2SS
Thanks!
I think we have it fixed and got some more power down low.
Is the M6 shifter supposed to move around so much while driving? Russell James V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 15 04-09-2012 01:05 PM
Get YOUR Driving On Track! Texas World Speedway, March 27 & 28 Apexer USA - Texas 4 04-03-2010 02:38 PM
Fog Light to Driving Light convertion!!!!!!! Cabrera Cosmetics and Lighting Modification Discussions 3 03-10-2010 09:01 PM
crazy son hoyhoy14 USA - California 16 10-26-2009 08:43 PM
Best Driving Roads stovt001 General Automotive + Other Cars Discussion 29 03-23-2009 12:08 AM
