10-04-2016, 08:07 PM | #1 |
Drives: 2013 Camaro 2SS/RS Join Date: Apr 2014
brake rotors need replacing
My SS has 18,500 miles. Original pads and rotors.
Pads are still good, but all 4 rotors need replacing from what mechanic told me. Is this normal? He didn’t recommend turning rotors either. I don’t track the car, it’s a daily driver and my braking habits are conservative. I don’t ride the brakes hard. Anyhow, I’m replacing pads with ceramic akebono's, and all around drilled and slotted rotors by R1 Concepts. Premier series. Hope they last longer. |
10-04-2016, 08:31 PM | #2 |
Todd
post a picture of your rotors. sounds like he is trying to take your money
10-04-2016, 08:55 PM | #3 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
Look at your rotors, are they smooth or do they have deep grooves? Can you see the pads, how much material is left? Finally, how foes the pedal feel, do you feel a pulse? Don't take one guys word, look or get a second opinion.
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
10-04-2016, 11:05 PM | #4 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
I've got 113k miles on my original rotors.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
10-05-2016, 12:20 AM | #5 |
Well, mechanic is not taking my money. He actually lets me buy the parts and he will just install. Rotors are smooth with very minimal grooves,
The ends of the rotors do create a lip. Pads are still good. I just decided to change the stock ones with ceramic. Changing out the rotors to drilled and slotted was more of a preference. I just wanted some feedback as to how long these rotors last. |
10-05-2016, 12:24 AM | #6 |
B.O.D. 02/16/10
Drives: 2010 SGM Sp. Edition 2017 RS Conver Join Date: Jun 2010
He's taking your money, but you are upgrading so all is well.
10-05-2016, 12:26 AM | #7 |
10-05-2016, 12:28 AM | #8 |
10-05-2016, 12:46 AM | #9 |
B.O.D. 02/16/10
I do the same exact thing. Time is always the problem, so I have others do some of the time and space consuming things. Hate that this what I have to do. I just have very limited time. Garages these days though charge like they are the best. And trust me I have had to pay for some real hack jobs that I should have done if I had the time and space.
10-05-2016, 12:56 AM | #10 |
I'm expecting to get another 50k out of my rotors.
10-05-2016, 04:23 AM | #11 |
Todd
keep your stock ones. the drilled/slotted ones are for looks only. the stockers will perform much better. my brembos have a little lip on the end of them as well, doesn't mean they are bad. im sure I could get 100k out of them at least. I would just save your money man.
10-05-2016, 08:11 AM | #12 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
When you replace the pads you SHOULD have either the rotors turned(if enough meat) or replace..why? so your new freakin pads can break in and take a set....otherwise the used rotor would cause accelerated wear of the pads....
these days almost no body turns rotors any longer..it's so cheap to just replace....peace out
2010 SS 2SS M6 - Tune by RDP dynoSteve!(Woot) - Daily Driver - 150K! - All work by me...
10-05-2016, 08:17 AM | #13 |
Drives: '15 SS 1LE, '69 Z28 drag car Join Date: Dec 2009
What braking issue did you take it to a mechanic for? What sparked the looking at the rotors?
To only way to tell if the rotors need to be replaced is if they are below min thickness. 30mm front 26mm rear Ask your tech what yours measure as. As far as your "upgrades", they are actually downgrades. The Brembo pads are great, ceramics are junk. Holes and slots in a rotor only take away surface area and offer a spot for cracks to start. When you look at the price of Brembo pads...you'll probably want to get some more use out of them before tossing them. The "upgrades" to your system are... step 1 - additional cooling, ducts and hoses to the front rotors and DOT 4 fluid. Step 2 - Big 6 piston front calipers and ZL1 rotors. Step 3 - a full big brake kit from Wilwood, EPC, Stoptech... The ceramic pad thing is for show cars that don't want brake dust. But they don't stop for sht. The factory Brembos are actually really good for street performance and mild track use if you add cooling and DOT 4. |
10-05-2016, 12:00 PM | #14 |
I worked for Midas for years and now work for Mercedes Benz in system skills. I got more miles out of the AutoZone pads than I did with the GM pads. I also never seen any accelerated wear in the field on customers cars. You machine because of run out. If that's good then it's not needed.
