12-19-2022, 12:09 PM | #1 |
ZL1 Short Block Question
So I recently just bought a 2017 ZL1 w/ 29,000 mi. I was planning on keeping as was, which is a rot fab CAI, and 1 7/8” long tube headers and full exhaust. But it was running lean I guess when I bought it and cause damage in cylinder 1 around 30,000 mi.
So now i am looking at either getting a 416 ci short block from weapon x, or just sending mine off. We are also going to cam it, port and polished heads, different supercharger pulleys, go to the big gulp Roto fab CAI, and a better clutch. Would I be better off sending my block off, or getting one from weapon x. And what kind of power should I expect. |
12-19-2022, 01:32 PM | #2 | |
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. 1116/967. 1.35/9.25/151 at 3500 ft. (only one pass) 15" conversion/MT ET Street R 325/50R15. |
12-19-2022, 02:09 PM | #3 |
The 416 imo isn't worth it unless you plan on doing a centrifugal supercharger which will net some bottom end torque back that you lose going from PD to Centri. Otherwise, you are compounding more torque on top of what the little 1.74 supercharger already makes and shifting the power curve to the left. Lehman's terms that is too much displacement for the stock supercharger. Save your money and just rebuild the 376. reuse the crank and rods...make sure to upgrade the thrust bearing. That is the weakest link in the LT engines and tend to allow the crank to walk on Supercharger builds north of 850whp.
2016 NFG 1SS A8
12-19-2022, 05:07 PM | #4 | ||
LME for the engine is the first choice. Katech does a nice job too.
12-19-2022, 05:10 PM | #5 | |
'20 ZL1 1LE A10.
12-19-2022, 06:49 PM | #6 |
I do plan on going with the magnuson 2650 in the future I figured this would be a good foundation for it. But idk thats why im asking
12-19-2022, 10:15 PM | #7 |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
The 2650 likes the extra engine size, so if that’s definitely the plan, I’d do the 416.
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
12-19-2022, 10:30 PM | #8 | |
Drives: 2019 Camaro Z-28 Join Date: Jul 2010
Well its already been posted but the BEST engine builder out there is LME and there are no close seconds. The fastest and MOST reliable streetable engines in the world. LME 416 would be the way to go with a full effort 2650. LME's precision on their engines puts them in a league of their own.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
12-20-2022, 08:20 AM | #9 |
I'd agree with Jason Zl1Atlanta about the 416 and the 2650. Both will handle all your wallet allows you. Plan of buying a set of drag radials for the street, you'll for sure need them. Good luck on your choice of short blocks.
12-20-2022, 08:29 AM | #10 | |
As for LME, what does their LT4 engine resume look like? Do they have a bunch of national records or series championships or what? I'll concede that they're good, but doesn't Pray have most of the fastest LT4 cars? I'm 100% sure that there's at least one Vengeance engine owner who will disagree with your LME statement. Also, Pratt Miller's GT4 engines must be as good as it gets. How would we determine that?
'20 ZL1 1LE A10.
12-20-2022, 08:47 AM | #11 | ||
2016 NFG 1SS A8
12-20-2022, 09:32 AM | #12 | |
2019 COPO #32
427 NA 9.38 142MPH 2018 ZL1-NFG-A10 388CI L8T 9.32 147MPH |
12-20-2022, 09:53 AM | #13 |
It depends on the HP your going to make but if your going to have someone build a forged engine this guy is exactly right. Yes it will cost you some more bucks but it may save you later. Mine junk the thrust bearing on my Manley forged motor on my 16ss, don't know that it would have saved my motor since it broke the crank internally but do what you can now and build it right.
