07-17-2023, 06:49 PM | #1 |
Drives: 2022 Camaro zl1 Join Date: Jun 2023
Msd atomic airforce Instead of TooHighPsi?
So I was looking at intakes and I noticed that the msd intake has bosses for Port injection and a fuel rail kit. If you were going to do Port injection and replace your intake wouldn't that be a viable way as well? You would still need a controller, injectors and all of that.
07-17-2023, 08:31 PM | #2 |
If someone were already considering purchasing an intake with built in port inj bosses, then thered be no need for the plates.
I went with the plates because i intended to keep the stock intake.
07-17-2023, 10:00 PM | #3 |
Yeah that makes sense. I am glad I started researching this way in advance. Everytime I start thinking I got something figured out I find something new that is a potential game changer.
07-18-2023, 07:14 AM | #4 |
You've got a lot of posts in various sections, and you are looking at the right things for the most part, but i dont recall if you ever said what your goals are.
We can help you get to your goals. Maybe a single thread either in this section, or in the forced induction section if you are going that route, would help to coalesce all the info and make it easier for folks to read your "build story" and see your thought process. I've been where you are, and folks here will help you weed through things and get what you need to reach your power goals. But i think it would help to just start and maintain a single thread. It will get the attention it needs and have your thought process documented as well.
07-18-2023, 09:57 AM | #5 |
Drives: 2016 Camaro SS Join Date: Oct 2021
Holley also offers a low rise intake with port bosses on it as well as BTR. The Holley looks to be pretty affaordable.
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Diamond Pistons/Manley Rods BTR stage 3 cam - Circle D converter American Racing headers - Borla S-type |
07-18-2023, 02:04 PM | #6 | |
When I first started looking at what I was going to do to improve performance, I thought I could slap a procharger on it over the weekend do some tuning and be good to go. Then start slapping on other upgrades one at a time until I was happy. Then you guys crushed my dreams with reality of the weak points of this platform and all the money time I am going to have to throw into it. My wife and I both make pretty decent money, so that is less of a concern once we pay off a couple of big ticket items that she wanted (a swimming pool, new suburban) so in reality I have to make her happy first before I start dumping money into my car...so I am guessing 2-3 years. End goals are: Procharger, full e-85, Meth, Cammed, intake, full exhaust, Heads ported and polished, tuned with me learning and tweeking it later. The big problem I am trying to wrap my head around is all the supporting things I need to do to get to those goals and what order to do it, and seems to keep snowballing. The fuel system is going to have to be upgraded, the engine internals will need to be upgraded...etc...etc. I am also lazy to a point where yeah I don't want to be ripping the car apart all the time to install the next thing so it makes sense to do it all in one big bang...but where do I stop? What start off as an idea to get a procharger on the car running e-85 and meth turned into just about everything being replaced but the block and now it is a 416 stroked motor pushing God knows how many hp's |
07-18-2023, 02:39 PM | #7 | |
Drives: 2022 Camaro 2SS A10 Join Date: Jul 2022
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods |
07-18-2023, 02:40 PM | #8 |
Unless you have the deep pockets to do everything at once I would build the engine and complete fueling system. Making sure the fueling system up what you are planning in the future. This will get you a decent bump in HP and set you up nicely for you future plans with a procharger.
07-18-2023, 05:25 PM | #9 |
I would ask... whats the fastest/highest hp thing youve driven to date? Because I dont have cam/heads etc... and ive pretty much made 1st and 2nd gear useless on the street. Itll blow off the tires if i punch it any any speed in those 2 gears, and the rest of them are dicey unless ive got hot pavement and hot tires (thats with DRs). So... you dont need everything and the kitchen sink too if it will only ever be driven on the street.
Itll be a wild ride just with just fueling and a forced induction of any kind.
07-18-2023, 08:37 PM | #10 | |
Want and need are two different things I get you and understand. Highest hp thing I have had is my 67 chevelle I sold a couple of years back. I never had it on the dyno but did get a single 10.5 pass on it on drag radials, all motor before they kicked me off the track(no roll cage). I was really past the point that it needed to be back halfed and running slicks, I just don't want a dedicated track car. You are 100% correct and by the time I actually start doing the things hopefully I will have come back to earth and realized I don't really need to spend 30k on my car to get all the shiny things. Keep trying to talk sense into me. I need it and my wife will be thankful. |
07-19-2023, 08:14 AM | #11 |
Youll run mid to high 10s pretty easily with a basic fueling/forced-ind package on E85. Laynlo is running in the 9's on a Maggie 2300 on a SBE. I did 10.84 on a PC with a shitty 4.13" pulley. Not sure what my new time will be after port inj and the 3.7" pulley. Hopefully mid/low 10s. Id throw a party if i did 9.99, but not feeling like thats likely unless i can get my 60 ft down. Also on SBE.
With that said, i dont want to dissuade you from forging the internals, because its almost unanimous that its the right thing to do. Ive owned up to the fact that if i blow the motor, its not for lack of folks here telling me to forge it. I have not gone that route yet, but nothing ive done so far prevents it later. You can run down to 9.5 (i think) in the 1/4 in a modern car (forget what year... like 2013+ or something) and not require any major safety mods. Im really just a noob pretending to know things There is nuance and infinite caveats to this and Im probably going to get chastised for saying this, but seems like if your goal is high-mid 10s youll probably be fine on fueling, FI and E85 on SBE. Faster than 10.5 and its starting to get dicey and would/should forge it. Another rule of thumb is if you are shooting for the 650 - 700+ rwhp on E85 then forge it. Threshold is much lower if you arent running E85. And if you are going to forge it, may as well do heads and cam too. Stay away from meth as fueling unless you are forged, and even then seems like it should just be used for cooling unless you have a good distribution system for meth. I havent forged or did heads/cam because i still have emissions testing to think about and i havent pushed the SBE to the limit yet. However i dont think ill go any further on the SBE than where im at, so may be at the limit now. I certainly dont want to lean it out any further than .78 to .80 lambda at 11-12 psi on SBE. So im losing a bit of power there. Im just rambling now after my morning caffeine so ill shut up now.
07-19-2023, 09:15 AM | #12 |
[QUOTE=cjperformance;11337716]. Stay away from meth as fueling unless you are forged, and even then seems like it should just be used for cooling unless you have a good distribution system for meth.
I am running forged internals on meth and flex fuel... keep in mind that I run Meth for cooling but it does have an effect on the fueling side as well.... Meth + Pump Gas (93)= ~E60ish... I don't really see a difference until I run close to full E85 in the car now with my set up. My tuner turned mine down to 832 rwhp for reliability and streetability (if there is such a thing), and of course running drag radials but still spinning the tires until I reach above 40 or so. 600-700rwhp with E is much more street friendly IMO. (but if ya going to take it to the track, you will want more )
