05-25-2019, 03:12 PM | #1 |
Installed gill vinyl today
Installed gill vinyl on the Camaro.
This was the first time I ever installed any kind of vinyl on a car before. I wish they were a little more like a model decal where you have some time to slide it around and get them just where you want them. But overall, it wasn't too bad. I had an easier time with the right side rather than the left. I'm right handed. On the right side, I used my left hand to anchor the decal and my right to "steer" the decal just where I wanted it. The left side was the other way around and I struggled a bit getting the decal right where I wanted it. But the left side looks OK.
2015 Camaro 1LE
2009 Challenger R/T 2007 Solstice GXP 2004 Colorado ZQ8 2002 Trans Am WS6 Collector Edition 1999 Blazer 1994 Grand Prix SE B4U |
05-25-2019, 03:29 PM | #2 |
Drives: 2014 2SS/RS Join Date: Jan 2018
Looks like you did good. You can use a spray bottle with a mixture of soap n water to glide them around like you are talking about then you just squeegee the moisture out.
Sent from my SM-N960U using Tapatalk
2014 2SS/RS LS3/M6
05-25-2019, 03:34 PM | #3 |
That's what I thought, but the instructions specifically said "no soap".
2015 Camaro 1LE
05-25-2019, 04:59 PM | #4 |
Drives: 10 2ss/rs Join Date: Jul 2018
Its probably same type material as a car wrap where you can pull it off and adjust it then the glue doest really activate till its heated up a lil bit
[/SIGPIC]10 2ss ls3 sw long tubes,cai intake,phastek scoop,se3" exhaust,elite e2, bw stg2tb, tsp f35, motive 4.10 lpw cover, 15" conversion, 510whp tuned by john donovan
05-25-2019, 05:53 PM | #5 |
The manufacturer said this:
"No soap at all. That works with vinyl/soap from previous decades. Newer vinyl is air release which allows water/air to come thru the material. Modern soap has skin moisture in it which causes vinyl not to stick. Sometimes it will stick short term, but really can cause adhesion issues."
2015 Camaro 1LE
05-25-2019, 05:58 PM | #6 |
I think people use baby shampoo not actually soap
2014 2SS/RS LS3/M6
