08-29-2015, 12:47 PM | #1 |
Let's go Rangers!
Tire pressure queston for thise who may know - Not for my Camaro
I have a 2002 Pathfinder stock height with 16" stock wheels.
Stock tire size is: 255/65/16 - Recommend tire pressure on side of door 30psi Today I got new tires and put on: 265/70/16 So my question is, would the recommend 30psi still be right, or something different? Thanks, Felix |
08-29-2015, 01:04 PM | #2 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
The pressure for the STOCK tires, that's on the door jam is still GOOD, and exactly what I would be running. No seed to change.
08-29-2015, 02:11 PM | #3 |
Let's go Rangers!
Perfect, thank you.
08-29-2015, 11:19 PM | #4 |
Drives: 2013 Camaro SS and 63 Impala Join Date: Feb 2013
But he's not running stock tires, wider and higher sidewall. I'm not a tire expert but if you're not running what's stock, I would run what the tire manufacturer says.
08-30-2015, 06:59 AM | #5 | |
Let's go Rangers!
From all the research I've done it appears correct to use the same pressure as recommended on the door. Felix - Speeding in my SS! |
08-31-2015, 10:11 PM | #6 |
Fine then! Guess that's why you're a Ranger fan. Go B's!
