01-26-2018, 01:16 PM | #43 | |
Drives: 2017 NGM ZL1 Join Date: May 2015
I agree with this as well |
01-26-2018, 01:17 PM | #44 |
How bad is your back?.... You can always sue for Diminished Value...?
01-26-2018, 01:23 PM | #45 |
Drives: 69 Z28, 2018 ZL1 1LE Join Date: Jul 2017
GEN6 Camaro is a unibody structure. The damage to the roof panel above the rear wheel indicates major damage to the unibody. Repair would be expensive and not structurally sound and a liability for anyone who operates the car after repair.
Total loss. |
01-26-2018, 01:52 PM | #46 | |
Drives: Love the one you're with Join Date: Sep 2009
Its just math boys and girls. If the airbags didnt go, with it being a rear hit, it would surprise me if they fix it with the cost of these cars. I have noticed the value of these cars dropping though, so that could factor in it being totalled instead of repaired. Especially if the salvage value is good. The percentage of cars getting totalled these days is going up. Its costing more to repair these things than it used to. Hope it's totalled for sure. |
01-26-2018, 01:57 PM | #47 |
That isnt the roof. That is part of the quarter. Well, on these gen6 cars the entire side is one piece. The roof looks fine and even the door gap looks good. Hell, even that rear wheel looks to be in the correct location. The wheel is bent but only on the lip.
01-26-2018, 02:07 PM | #48 |
The unibody in the gen6 isnt aluminum. Only the instrument dash support. It has aluminum suspension mounting supports and other suspension parts along with much of the sheet metal, but the unibody is high strength steel. That too has to be treated differently thoguh when repairing it. I.e. not using heat to bring it back.
01-26-2018, 02:10 PM | #49 |
Flyin NOE
Drives: 2018 ZL1 (A10) Join Date: Apr 2017
The frame is aluminum right?
If so, getting an aluminum unibody frame back into tolerances is going to be difficult. I'm also willing to bet the margins for frame straightness are fairly thin considering the fact it was engineered as a track car. His performance mods should also back up his intent to race the car. While I'm not sure if that would affect the decision by the insurance company to fix v. total, I would bring it up just to force the fact that this ain't no regular sedan. |
01-26-2018, 02:19 PM | #50 |
01-26-2018, 02:29 PM | #51 |
Drives: SS-6-SPD Join Date: Jan 2017
ouch!
glad you're okay man. |
01-26-2018, 02:34 PM | #52 |
Drives: 2013 ZL1 and 2019 Ram Laramie Join Date: May 2017
Being a unibody, the "frame" includes the roof and those pillars and panels leading to it.
There is no question it can be welded, bent, straightened, etc. until nearly as good as new, but at what cost? Also, more often than not, if the one part of the body is mangled, as in this case the right rear quarter, that shock transfers to other parts of the body as well. In other words, the right rear is not all that is effected by this collision. In sum, I don't know that you can get all the tweaks out. You may be able to get it to look right. You may even be able to get it to drive (track) reasonably straight. It will still be tweaked after an awful lot of work and product. |
01-26-2018, 02:37 PM | #53 |
Flyin NOE
Thanks for clearing that up.
Having said that, parts of the frame are aluminum and aluminum is not as forgiving as steel, once you tweak it it's generally f-ed. To add to what JB ^ said, that shock traveled throughout the unibody and likely tweaked pieces and parts throughout the chassis. Getting everything back into tolerance is gonna be difficult at best. |
01-26-2018, 04:57 PM | #54 |
Drives: 13 Boss 302 TT, C7 Join Date: May 2017
Looks repairable, idk what state ur in but Insurnace is not going to want to give u a new car. They will wanna fix it and make u Take it like that. They don’t care it’s new brand new none of that. Sorry this happened but unless u get a lawyer and pay him some money ur for sure stuck with pushing insurnace people who will take care of themselves first before u.
01-26-2018, 05:00 PM | #55 | |
Drives: 17 NFG ZL1 17 GTR 22 RS6 Join Date: Apr 2017
01-26-2018, 05:05 PM | #56 | |
Flyin NOE
I'd get a lawyer consult and see what they tell you. |
