Old 12-08-2017, 09:41 AM   #1
DoctorDrubs
Drives: 2017 1LT v6
Display was dead this morning
2017 with the base cluster. This morning, did a remote startup (it was 32 degrees outside). When I got in the car and hit the start button, the 7" display was off and non-responsive to any input. Shut the car off and restarted same. Not even the backup camera. Drove to the store, and when I came out, all was back to normal.
Anyone experienced this? Possibly related to the system update I see mentioned in a prior thread?
DoctorDrubs is offline   Reply With Quote
Old 12-08-2017, 02:00 PM   #2
PackersFan26
PackersFan26's Avatar
Drives: 2017 Summit White 2SS
I know they just rolled out an update recently. Maybe it had something to do with that
Follow me on IG: @lip_stick.ss
PackersFan26 is offline   Reply With Quote
Old 12-08-2017, 02:41 PM   #3
2K16SummitSS
Resident Land Surveyor
2K16SummitSS's Avatar
Drives: 2016 Camaro 1SS - Summit White M6
Mine has done this now and then in cold temps since I bought it Sept 2016, and I have the 8" screen... mine came with Android Auto from the dealership, no updates since I've had it that I know of. My guess is the head units are sensitive to temperature, but who knows. Hopefully not a bad solder issue like the BCM in the 4th gens back in the day....still dealing with that in our 01 T/A...
2016 Summit 1SS 49th Anniversary Commemorative Limited Plutonium Edition - M6, Solo Axleback & !RearCats, Ultra-Rare Cloth Seats, Forgestar CF5V 19x10-285/35 19x11-325/30
2001 NBM Trans Am WS6, Wifey's Grocery Getter - Torquer V2 cam, Racetronix Fuel Pump, Yank 3000 Stall, Transgo 1-2 kit, TSP LTs, Magnaflow, Strano Springs/Koni STR.T shocks, 17x9.5/17x11 TTIIs, Ed Wright tuned
2K16SummitSS is offline   Reply With Quote
Old 12-08-2017, 09:32 PM   #4
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
Pull the display fuse in the trunk. Open the door so the display would otherwise turn on so you quickly drain any power in it. Close the door and go put the fuse back. You should be good to go.
If you don't have success, there's a good chance of a hardware issue. Loose connection somewhere or botched update.
Old 12-19-2017, 10:10 AM   #5
wjmeyer
wjmeyer's Avatar
Drives: 2016 Camaro RS, 2LT
Also see this thread for mylink blackouts:
http://www.camaro6.com/forums/showthread.php?t=507539
wjmeyer is offline   Reply With Quote
Old 12-31-2017, 01:27 PM   #6
The Intimidator
Drives: 2018 Red Hot Camaro ZL1
Mine stays black for about ten minutes and then comes on, resets all the dash gauges too when it's around 33 degrees or lower. It's been in the teens/ 20's the past few days and the car has to sit and warm up for ten minutes at least before my display works. It does not like the cold at all. I hate that it does this. It's fine when it's around 35 degrees and warmer.
The Intimidator is offline   Reply With Quote
Old 01-04-2018, 08:41 AM   #7
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
If its going black random then that is signs that the HMI module is failing. i would go back to the Dealership ASAP and get it logged so they know its failing and can order you a new one.
SSTony is offline   Reply With Quote
