01-14-2013, 11:01 AM | #1 |
Drives: 67 vette Join Date: May 2011
DUMB question... battery
So this is probably one of the lamest questions ever posted on here, But ill ask anyway. I have on the fire suit lol..
Where the heck is the battery on a 2011 convertiable. Ours has 303 miles on it, I know i suck and its never driven, anyway i want to put the trickel charger on it so doesnt go dead.. Pop the hood.. No battery, so im like ok in the trunk.. pop the trunk no battery.. |
01-14-2013, 11:04 AM | #2 |
Under the cover on the floor of the trunk. Removed by unscrewing the fastener in relatively the center of the trunk floor.
01-14-2013, 11:05 AM | #3 |
SYBIL
Drives: 2013 2SS/RS, silver ice metallic Join Date: Oct 2012
the only stupid question is the one that you dont ask, yep, the battery is in the trunk under that cover along with your little air compressor, so when you have a blow out you can air it back up
01-14-2013, 11:07 AM | #4 |
[COTW 5/12/14]
Drives: 2012 CRT NF Cammed 2SS/RS For Sale Join Date: Oct 2011
dont feel bad, this gets asked often.
At least youre not one of those people who disconnect the battery, close the trunk and cant get back in to hook the battery back up |
01-14-2013, 11:08 AM | #5 | |
Drives: 2012 2LT 45th convertible Join Date: Jul 2010
We don't know that yet !
Top Ten Reasons I Procrastinate
1. |
01-14-2013, 11:18 AM | #6 |
Drives: 2011 camaro ss2 I.O. M6 Join Date: Nov 2012
01-14-2013, 11:23 AM | #7 |
Drives: '13 Dusk Edition 2SS/RS M6 Join Date: Nov 2012
01-14-2013, 11:27 AM | #8 |
Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
Go in through the back seat and pull the mafia handle.
01-14-2013, 11:52 AM | #9 |
Drives: 2013 Camaro 2SS RS Convertible Join Date: Jul 2012
If using a trickle charger like a Battery Tender or the like, yo can hook it up under the hood, by usingthe postive post (easily dentifiable under the red cap) and the small negative post (located on the edge of the fender). You will see a silver covered rod sticking out near the edge.
01-14-2013, 12:30 PM | #10 |
[COTW 5/12/14]
01-14-2013, 12:36 PM | #11 |
Drives: 2013 Triple Black ZL1 Vert M6 ECF Join Date: Mar 2011
On a convertible, there is a key lock for the trunk located between the drivers side of the rear seat and the drivers side panel. It's rather hidden. Your car should originally have had a sticker on the panel to show where it's located.
01-14-2013, 12:48 PM | #12 |
thanks guys.
I guess ill have to do some searching for it. when i looked i couldnt get the carpet up with out taking it all appart, and then the crap for the top is back there too.. |
01-14-2013, 01:43 PM | #13 |
The key lock on the convertible is between the seat back and the side panel right around elbow high IIRC. It's tuck way back in.
01-14-2013, 01:46 PM | #14 |
Drives: '11 2SS, '11 C6 GS, '04 MDX Join Date: Feb 2012
This is why I drape a nice clean furniture pad over the trunk lid when I disconnect the battery. This makes sure it doesn't accidently get closed.
